How to Open a Young Thai Coconut
Published
Introduction: How to Open a Young Thai Coconut
There are many recipes that call for young thai coconuts. It’s a common ingredient used in raw meals. There are many health benefits. Both the water and meat can be frozen too. I have tried many methods of opening a young thai coconut and have found that using a cleaver is the easiest. These instructions can also be found at gardengirlrecipes.com.
Step 1: Trim Top of Coconut
Trim away the top exterior flesh of the coconut with a cleaver.
Step 2: Tap With Cleaver and Open
Gently tap the surface of the coconut with the cleaver making a circle around the trimmed portion. You should be able to lift the trimmed portion and open the coconut.
Step 3: Drain Coconut Water
Drain the coconut water through a sieve.
Step 4: Pull Coconut Meat Out
Using a spatula, gently separate the coconut meat from the walls of the coconut. Once all the meat is separated, pull it out of the coconut.
Step 5: Wash Coconut Meat
Rinse and remove the brown skin that got pulled off with the meat. Generally it peels right off.
Coconut Challenge
Runner Up in the
Coconut Challenge
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    3 Comments
    Very nice instructable. I use 2 knives to open mine, a chef's knife for trimming(easier to control) and a cleaver for cracking the shell.
    Young coconut meat is much softer than its mature counterpart and is quite a bit easier to get out without scraping. I highly recommend trying milk made from a young coconut, it is creamier and more flavorful than from a mature coconut and I use it in my smoothies every morning. It also makes a fabulous coffee creamer without all the junk commercial versions add.
    That sounds yummy! I will have to try making coconut milk. Thanks for the idea!
    That is crazy how the meat of it comes out! I thought you'd have to really scrape it to get it out of there.
