How to Perfectly Hang a Picture That Requires Multiple Nails
Introduction: How to Perfectly Hang a Picture That Requires Multiple Nails
Home Hacks Challenge
Runner Up in the
This "ible" outlines the steps for a stupid little trick (which I picked up years ago) to perfectly hang just about anything that requires more than one nail/screw/cleat. It works just as well for pictures, as it does for power strips (or just about anything else you can imagine). I've wanted to capture it in this format for a while... but I'm lazy.
All you need are:
- Tape
- A marker
- A level
- A hammer (or other smashy-smashy device)
- Two Nails (or other pokey-outy devices)
Step 1: Painter's Tape and a Marker
Tear off a piece of painter's tape that's long enough to cover both the hangers. It doesn't have to be perfect piece of tape. It just has to be long enough to reach BOTH hangers. I like to use painter's tape, or masking tape, because it's usually accessible; it doesn't stretch much; it's easy to work with (meaning it's not so sticky that it tears or damages the things it touches).
Take your handy-dandy marker, and mark the apex of each hanger (wherever you expect the nail will go). The smaller the mark, the more precise your work will be. Note that I set it up so that the dots fall in the middle of the tape (vertically)? There's a reason for this. Once both of the hooks are marked, remove the piece of tape from the back of the frame and carry it with you to the wall where you intend to hang the picture.
Step 2: Transfer the Marks Onto the Wall.
Slap your tape on the wall in a "yeah... that looks pretty close" kind of way. Then get out your level. Pick one of your dots, set the level, and make your "T" marks (on the tape, not the wall).
This is the reason for putting the marks in the middle of the tape. Some of us are good at "eye ball" leveling. In this case, I was only off by about a quarter of an inch. Not everyone is so "skilled." You want the marks to be in the middle, so that you end up making all of your leveling marks on the tape (rather than the wall).
Step 3: Nail Through the Tape
Using your chubby digits (if you're lucky enough to have "chubby digits"), tap your nails through the tape. Repeat.
Once both nails are in place, peel the tape off the wall. See? No unnecessary marks? No "extra" holes.
Step 4: Hang the Picture!
See? It works.
Now, the part where you figure out how to get those stupid, flippy-style, triangle-shaped hangers to actually HOOK ONTO THE DOGGONE NAILS, is entirely *your* problem.
I suggest spending several thousand dollars on a fiber optic camera. You know, the ones you see in movies with the small LCD screen? It might also come in handy if you ever have to diffuse a bomb, which... come to think of it... I would probably rather do than mess around with these types of hangers.
Step 5: Place Fancy Things Around the Picture
Take a second to be pleased with yourself. Nothing got punched. Minimal curse words were used. No unnecessary holes in the wall. You did this the smart way. Why not assemble a collection of your most pretentious books and decorative doo-dads in front of the picture, so that you can take a picture... of the picture.
Good luck!
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    What an easy work! Genius idea! How it come I haven't come up with this trick? Thanks for your instructable :) Hope you find some extra time also to check out my curtain holder DIY ! I guess you may like it, as you love "hanging stuff" LOl!!!
    Great instructible, nice write-up. I've actually done this before, and would like to add some observations from my experiences:
    I've found on some hanging frames that the hangers aren't always even or level, one may be mounted a bit higher or lower than the other side - usually it's the cheaper frames. This leads to two problems - when you put the tape on the wall and then level the marks, the frame will not be level. Second, if you notice it's unlevel, and account for it, be sure to remember that the tape will be reversed on the wall....when you mark your left on the tape while it's on the frame, it's actually the "right" side of the frame when it's hanging.
    I eventually started placing a strip of tape across the hangers, as above, but long enough to extend past the frame, and mark the holes. Then I hold the frame to wall, level it, and then using two more pieces of tape, secure the first tape to the wall, sticky side out. Carefully remove the frame (it's sticking to it, remember), and then install the nails.
    You missed the part about "I'm lazy." (Just kidding.)
    I totally understand what you're getting at, and you're right. Cheap frames are famously imperfect.
    Totally understand, and relate to, the "lazy" part!
    But OCD wife (and myself to an extent) makes that not an option here :)
    Awesome! I did have one where the little triangle thingys weren't level with each other. I just adjusted the nail on one side a little and VOILA!
    very nice and simple. like sliced bread!
    HOLY COW! You are my hero!!! I HATE those stupid picture frames so much. Seriously you just made hanging pictures so much better
    You're MY hero, Bane! Soon the darkness will become familiar to all, amIright? Batman didn't know what he was getting himself into.
    Seriously though... Thanks. And keep rocking the safety gear.
