How to Photograph the MOON
19,243
196
41
Posted
Introduction: How to Photograph the MOON
Photography Contest 2017
Second Prize in the
The moon is the most beautiful object in the night sky and makes the otherwise boring night sky look more interesting! we've all tried to photograph it and failed miserably.
This is a simple guide to photographing the moon using a DSLR or a point and shoot camera and will help you better your photography skills!
Step 1: Requirements
1. Camera. A DSLR would be preferable because of higher quality photographs taken by it.
2. Zoom lens. the bigger the zoom the better it is.
3. Tripod. this helps us take sturdy and solid photos and avoids even minimal blur.
4. Remote trigger (optional).
Step 2: Setup
Camera - the camera I use is Canon's entry level basic DSLR called the canon 1200D. Any DSLR will do as long as you know how to operate it. You can even use point-and-shoot cameras but obviously the quality will be lower.
Lens - a zoom lens is with a zoom of minimum 200mm is needed. I've used a 55-250mm zoom lens which does the job pretty well. this is a kit lens that came with the camera bundle when i bought it. The bigger the zoom the better your photos will be.
Tripod - this is a definite necessity. a sturdy tripod is needed to prevent any shake. even a small blur can have a huge impact when photographing something like the moon. If you're not able to find a tripod then rest your camera on a rock or a ledge and make sure it's secure and stable.
Shutter Release - this will again help you prevent shake but it's not a necessity. I managed to produce the exact same photos by putting a timer on before taking my photos.
Step 3: Camera Settings
  • First, put your camera in the MANUAL MODE.
    This is represented as an 'M' on Canon cameras.
The Triad (ISO, shutter speed, Aperture)
  • ISO- start with an ISO of 100 for test shots. increase it to 200 then to 400. normally you wouldn't require a higher ISO.
  • APERTURE- use between f/8 to f/11. try whatever works for you.
  • SHUTTER SPEED- start between 1/125 and play with it till you get it right. most of my photos have a shutter speed of 1/325.
  • FOCUS- I prefer autofocus itself while photographing the moon. but if you're confident enough, you can set it to manual focus and focus it to infinity.
    Also, use Spot metering on your camera.
Step 4: Starting Out
First, choose a day which will have a FULL MOON.
moon photographs come out best on full moon days. You can search online for days on which you'll see a full moon. A lunar cycle is about a month. Plan it accordingly.
Location - choose a place that has relatively less light pollution for crisper photos.
Weather - You will need a clear sky to photograph the moon. even a thin layer of clouds makes the photo hazy and will be undesirable.
Time - if you want the size of the moon to be bigger, take the photo when the moon is just on the horizon. However, if you want sharper and more detailed photos, take them when the moon is higher up in the sky.
Step 5: Taking the Photos!
Let's start taking photos now!
  • Point the camera at the moon and fix your tripod. also activate the live view feature on your camera so that you are able to see a live image of the moon on your screen.
  • Zoom as much as possible towards the moon.
  • Now, using the shutter release cable or a timer on your camera take as many photographs as possible.
    Keep playing around with the ISO, Shutter speed and aperture till you get the best looking photos.
  • Use the digital zoom on your camera to zoom in on the moon to check for any blurring. and then continue to take more photographs!
  • After you get your desired photo, transfer it to your computer and crop it to it's size.
    now you can either leave it at that or do post processing.
Step 6: Blurring and Exposure Problems
I've attached examples of photos that are Blurred (because of camera shake and vibration shake) and photos underexposed and overexposed.
This can be prevented by practice and taking more and more photos. underexposure is always better than overexposure because the brightness and contrast can be increased in post processing.
Step 7: Post Processing
Most of the times, a moon photograph comes out pretty good by itself if all the steps are followed. But if you feel there is a need to enhance the photo then you can do the following in Photoshop -
Open Adjustment and under it Curves and select “Medium Contrast” Preset from drop-down menu and click on “OK”.
Then, click on Filter, then Sharpen and then Unsharp Mask and add 150% in “Amount” field, while keeping the “Radius” on 1.0 pixels and “Threshold” at 0 level.
This will help you improve your photo even further!
Step 8: How to Do It Using a Point-and-shoot Camera
Just because you don't have a DSLR, it shouldn't stop you at all!
these instructions are only for Sony point and shoot cameras.
Go to 'Camera Mode' and select 'P' that is Program Auto mode. Set the White balance to 'Auto' and set the metering to 'Spot Metering'. now point your camera towards the moon and zoom in as much as possible. now zoom out a little bit (you can crop and enlarge the photo later) and click the photo. Obviously the photo quality will not be as good as a DSLR but it'll still be pretty good.
Step 9: Practice Practice Practice!
The more you practice the better your photographs will get.Once you're able to perfectly Photograph the full moon, then you can even photograph the moon during it's various phases of waxing and waning.
Here is my best photo of the moon and I've also attached the photo details with it.
do post your photo of the moon when you try it out! :)
Also, If you like this instructable then please do vote for it in the 'Photography Contest'.
4 People Made This Project!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
31 Comments
Nice i'ble. Maybe I'm gonna try it at the next weekend. :)
As far as I know, the amount of ISO depends on the model of the DSLR your are using. Must be handled individually.
A good rule of thumb:
ISO 100-200 - Daylight, shining sun, bright rooms/halls
ISO 400-800 - Cloudy skys, early evenings
ISO >800 - At night, dark indoor
Good info, especially the shutter speed/aperture.
One comment - on several occasions, you mention something to the effect that a DSLR will somehow automatically take better quality pictures than other types of cameras. If you were meaning that a 100% automatic camera would have limitations due to its lack of settings, that's applicable. If, on the other hand, you're trying to say that the something about a DSLR's imaging capability is inherently superior to other types of cameras, that's unsubstantiated. A high end adjustable "point and shoot" with a good, name brand lens system will produce higher quality images than an inexpensive DSLR. A DSLR is desirable for a number of reasons, but absolute optical quality is not necessarily one of them.
I basically meant that on a DSLR it is possible to control all setting of the camera and change them to suit our purpose!
and yes i do agree that a super high end point and shoot can at times produce better images than a low end DSLR.
Nice instructable. I use a bridge camera all the control, longer zoom but non of the weight of a DSLR. I have often found the Manual focusing to infinity and then backing off by one increment gives good focus results.
Oh, and here is my moon picture from wayyyy back in January 2009. It was taken with a Nikon D50 DSLR (their cheapest / crappiest model available at that time) and the 55-200mm 'kit lens' that came with it (also pretty horrible). I don't believe there was any post processing done to it at all, other than cropping the vast amounts of black space around it in MSPaint. Haha. So this is basically how it came 'off the camera'. The EXIF data seems to have been stripped away from the file, but I'm pretty sure I was shooting with the aperture wide open (which was only f/5.6 at 200mm zoom on that lens) and then just adjusted the shutter speed until I got an exposure that made me happy. The picture is maybe a tad over-exposed, but I had just got the camera (my first DSLR) for Christmas and was pretty new at this stuff (and didn't know about .NEF / .RAW mode), so I think it came out okay!!
"If, on the other hand, you're trying to say that the something about a DSLR's imaging capability is inherently superior to other types of cameras, that's unsubstantiated"
Actually, this is most definitely *not* unsubstantiated. A DSLR camera generally has an image sensor 10 to 20 times larger than a 'point-and-shoot' camera. This has nothing to do with how many "megapixels" the camera has. It has to do with the size of the individual photoreceptors on the sensor. The photoreceptors on a DSLR image sensor are *much* larger than those of a point-and-shoot camera. This means that they are more sensitive to light and therefor the camera does not have to provide nearly as much 'gain' to the raw sensor data to produce an image (*ALL* digital cameras do this, BTW). This results in images that have: better contrast, better sharpness, better color reproduction, etc.
Obviously, the quality of your lens will also play an important role, but it is the larger sensor size of DSLR cameras that give them an advantage over the tiny image sensors found in point-and-shoot cameras.
I would recommend doing a Google search such as "why sensor size matters" and read up on this before YOU make unsubstantiated claims on why you *think* that all cameras are created equal. They are not. Facts will always out-weigh opinion.
Thanks for weighing in with all the technical details! :)
Nice instrucable. I really enjoy moon photography, and you've done a good job explaining it. I've also found that, especially at night in humid summer months, lens fogging is a problem. When you take your camera and lens from a cool air-conditioned space to a warm humid space, the condensation will form pretty quickly on the lens. When I want to shoot the moon in the summer, I wrap my camera in a towel and leave it outdoors (in the car is usually good) for an hour or so, just to get it the same temperature as the outside air. That really helps keep it from fogging up and decreasing the clarity of the photos. Also bought a telescope adapter to use my camera with a 900mm telescope for some really nice detail.
I used a C8 with a T adapter.
When I download this it chops off the bottom of the file. When I print it the top of each page is overwritten with the top banner. I am using an android Samsung tablet and Chrome browser.
