Step 8UPCB Cable
DREAMCAST Looking at controller end that plugs into the Dreamcast ___________ | 5 3 1 | \ 4 2 / --------- Pin Description Standard Wire Color 1 Serial A red 2 +5v blue 3 GND black 4 sense green 5 Serial B white Line 4, 'sense', is connected to ground in the controller. The Dreamcast uses this line to detect when there is a controller in place. Since we can connect it to ground inside the UPCB console cable hood, there is no need to connect this to the UPCB itself. To make a UPCB cable for the Dreamcast Piggyback, match up pins like this: D-Sub 15 Pin GC Pin 1 3 (GND) 2 Low 3 Low 4 High 5 High 6 Low 7 Low 8 2 (+5v) 9 NC - Not connected to anything 10 High 11 High 12 NC - Not connected to anything 13 1 (Serial A) 14 5 (Serial B) 15 Low You'll want to also solder in the 'sense' line to any one of the 'Low' lines. I soldered mine into 15 along with the little jumper wire that connected it to the rest of the 'Low' lines.
Wiring up the Dreamcast Piggyback cable is no different from wiring up any other UPCB cable. Connect all of the High and Low pins, then connect the wires from the cable itself, and you're done. Please check out the other two Instructables on making a UPCB cable:
How to build a console cable for the Universal PCB.
Add Comment
