How to Play the Trumpet
2,136
6
Posted in PlayInstruments
Introduction: How to Play the Trumpet
Have you ever wondered how you play the trumpet, and you never got the opportunity to learn it? Well now you have the chance to learn it in not time.
Step 1: How to Blow Into the Trumpet
Many people think that the correct way to blow into the trumpet is just blowing into it, when the cheeks are then blown up. This is not the correct way, since it actually makes it harder to play the trumpet. The correct way to blow is by bending the upper lip downward a little bit, and let out air. Then a sound is released, which is the note. This makes it easier to play the trumpet. To play higher notes, you have to bend the surface of the tongue upwards.To play lower notes, you have to lower your jaw. To have a different note, you have to change the fingering, which is explained, in the next steps.
Step 2: Notes for Pressing No Valve
  • H sharp
  • C
  • G High
  • E High
  • F flat
  • High A sharp
  • High B
  • Higher D
  • Higher E sharp
  • Higher F
Step 3: Notes for Pressing the First Valve
  • A sharp
  • B
  • E sharp
  • F
  • High Ds
Step 4: Notes for Pressing Second Valve
  • H
  • C flat
  • F sharp
  • High D sharp
  • High E flat
  • Higher C sharp
  • Higher D flat
Step 5: Notes for Pressing the Third Valve
  • A
  • E
  • F flat
  • High C sharp
  • High D flat
Step 6: Notes Using First and Second Valve
  • A
  • E
  • F flat
  • High C sharp
  • High D flat
Step 7: Notes Using First and Third Valve
  • G
  • D
  • H
  • High C flat
Step 8: Notes Using Second and Third Valve
  • G sharp
  • A flat
  • D sharp
  • E flat
  • H sharp
  • High C
Step 9: Notes Using All Valves
  • F sharp
  • G flat
  • C sharp
  • D flat
    • Make it Move Contest
    • Flowers Challenge
      Flowers Challenge
    3 Comments
    As a long standing brass player (30 years) there is no easy way to play a brass instrument. The blowing instructions are not helpful, you need to make a buzzing sound to get a note.
    It takes time, effort and either professional or experienced guidance to do it even close to properly.
    The one who was writing this instructable was using the german note names.
    H = B
    B= Bb
    I have to agree. At first I thought it was a typo but after the second H and then the third... Actually you might want to consult with a professional bonafide trumpet instructor on how to toot your horn.
