How to Polish Polycarbonate Bug Deflector
Introduction: How to Polish Polycarbonate Bug Deflector
Video tutorial on how to polish a bug defector. Just like your headlights, bug deflectors can fade over time. Besides bug deflectors, this tutorial also applies to the wind deflectors found around the windows too. These are normally made of a polycarbonate or also known as lexan.
Tools/Supplies Needed:
  • polishing compound
  • wax
  • microfiber cloth
  • clean clothes
  • carwash soap and water
  • bottle of water with spray
Step 1:
Start by washing the vehicle so all dirt and contaminants have been removed. This will ensure we don’t contaminate the polishing process and create any unwanted scratches. Also make sure behind the deflector is clean, this is a hard to reach area and can be overlooked when washing a vehicle.
Normally the back side doesn’t fade as it is somewhat protected by the elements. So there really isn’t a need to remove it from the vehicle.
Stick some clean cloths behind the deflector so it won’t flex too much and risk rubbing against your paint.
Step 2:
Using a polishing compound, apply it to a soft cloth.
Work the product into the surface applying medium pressure.
Depending on the type of polishing compound you are using, a mist of water can be applied to moisturize the compound.
Apply more compound when needed.
A machine buffer can be used, but considering these normally aren’t a flat surface we can risk burning the finish. This normally doesn’t take too long by hand either, for this particular deflector it should only take about 20 minutes at the very most.
Step 3:
Once satisfied, give the deflector a wipe down with a damp clean cloth to remove any compound residue.
Sometimes the surface maybe etched from bugs, so you can give it a light stand with 2000 grit wet/dry compatible sandpaper if you wish.
Make sure the deflector is dry and then finish up with a wax of your choice to protect the surface from fading again, along with giving it a final shine.
Just like your lights, wax should be applied to these deflectors every time you wax your vehicle so it prevents them from fading again.
Stay up to date with my latest tutorials, don't forget to FOLLOW my profile and be sure to check out my YOUTUBE page as well for all your DIY needs.
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    sir gud morning
    how to make car dash board polish
    Nice tutorial on cleaning and polishing that bug shield. Very similar to headlight lens polishing as well.
    I used to have such a bug shield on a vehicle. And I was getting a lot less gas mileage then usual. So after a while I removed it and my gas mileage went back up. I am talking between 1 to 2 MPG as well. So it my deflect bugs, but at the cost of a couple miles per gallon. At least on my vehicle. So I will deal with a few bugs now. JMHO
    Thank you! I'm surprised to hear it made that much of a difference, but it makes sense. I installed a deflector on my old truck years ago, certainly helped keeping the dirt off the windshield but I didn't pay attention to the fuel change though.
