How to Prepare Any New Aftermarket Auto Body Parts for Painting
99
5
Posted
Introduction: How to Prepare Any New Aftermarket Auto Body Parts for Painting
This video will show you how to correctly prepare for painting any new aftermarket replacement part.
Make sure to visit http://www.themechanicdoctor.com for more info, tutorials, tips and awesome resources for auto mechanics!!!
Step 1:
TOOLS NEEDED:
  • 320 & 500-grit sandpaper
  • Abrasive pad (Scotch-Brite)
  • 1 can of Gravel Guard
  • Spray gun
  • Primer sealer
Step 2:
INSTRUCTIONS:
1. Start by roughly sanding the black primer using the 320-grit sandpaper.
Step 3:
2. When you're done, use the abrasive pad and sand the fender once again.
Step 4:
3. Repeat the process for the other side. Make sure you don't miss a spot.
Step 5:
4. Watch out for imperfections and dents that could need some fixing prior to applying primer. What you want is a smooth and even surface.
Step 6:
5. If any areas of the new part are going to be exposed to the road like the inside of a fender, we strongly suggest you spray it with gravel guard to protect it from minor dents and premature rusting.
Step 7:
6. Wipe off any excess gravel guard and drips with a shop rag and let it dry.
Step 8:
7. When dry, spray the interior of the fender with 2 fine coats of sealer primer. Let it dry.
Step 9:
8. Repeat the process and spray the outside with 2 fine coats of sealer primer and let it dry completely according to the manufacturer's recommendations before moving onto next step.
Step 10:
9. When the primer is completely dry, sand the fender once again using the 500-grit sandpaper. Watch out not to sand through the primer!
Step 11:
10. Finish sanding using the abrasive pad one last time.
Step 12:
11. Repeat the process for the other side.
Step 13:
12. Use a blow gun to remove dust from the fender and wash it with any good surface cleaner.
Step 14:
13. Make sure you are in a well-ventilated room and wear the appropriate safety gear from now on.
Step 15:
14. To remove any dust or sand left, wipe the fender thoroughly inside in out with a tack cloth.
Step 16:
15. Because you won't be able to paint it once the fender is mounted on the car, spray paint the interior beforehand. Let it dry.
Step 17:
16. Apply another coat of paint. Let dry.
Step 18:
17. When completely dry, wipe the fender once again with a tack cloth.
Step 19:
18. Apply one good coat of clear coating on the inside of the fender. Let dry.
Step 20:
19. Install the fender on the vehicle and prepare surrounding areas to receive paint.
Step 21:
20. That's it!
If you liked this video and found it helpful feel free to like, share, and comment to help us bring you even better content.
For more oil reset, cabin air filter replacement and DIY car maintenance tutorials, make sure to visit www.themechanicdoctor.com and to subscribe to our channel!
If you didn't find what you were looking for, send us a message with the model and year of your car and we will get back to you shortly with the best answer we can find.
Also, if you would like to contribute with an oil reset video of your own or any other car related tutorial, just send us an email with your video and we will be glad to credit you or your shop and to include your name or logo in the uploaded video. Here's your chance to get a little more exposure for free! :p
For any question or suggestion, post a comment below or send us an email to: themechanicdoc@gmail.com
Jee
  • Gluten Free Challenge
  • Epilog Challenge 9
    Epilog Challenge 9
