How to Program Attiny2313 and DIY Development Board
624
13
Posted
Introduction: How to Program Attiny2313 and DIY Development Board
In this tutorial, we will learn how to make DIY development board of attiny2313 on perfboard. And how to upload program on it.
Step 1: How to Program Attiny2313
First of all, Attiny2313 is a 8-bit low range microcontroller from Atmel. It's a 20-pin IC (DIP, through hole package).
It have internal rc oscillator that supports frequency 1 MHz, 2 MHz, 4 MHz and 8 MHz
List of components:
  1. Attiny 2313 with ic base
  2. Perfboard
  3. Male header
  4. Female-female jumper wire
  5. USBasp programmer
  6. AVRdudes
  7. AVRStudio (any version, I am using version 4)
  8. USB cable type-B
First of all, make development board for attiny2313 as given in the figure.
Step 2: Connections
Make connections as follows:
USBasp Attiny2313
GND ========> GND (Pin no. 10)
VCC ========> VCC (Pin no. 20)
RST ========> RST (Pin no. 1)
MISO ========> MISO (Pin no. 15)
MOSI ========> MOSI (Pin no. 14)
SCK ========> SCK (Pin no. 16)
Once the connection is done, connect USBasp programmer to laptop/ PC. Open avrdudes, and follow the steps and given in the picture.
Open avrstudio, and copy the code in the editor. Compile the hex file and upload it using avrdudes.
Step 3: Final Connection
Add led array to the attiny 2313 development board. Cathode of all the led's are common and is connected to the ground of the development board.
A series resistor of 220 ohms is connected for limiting the current.
Leds are connected to portb.
Hope you had enjoyed the tutorial !!
Thanks for visiting this tutorial
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
