How to Program Your Attiny || DIY Decision Box
Published
Introduction: How to Program Your Attiny || DIY Decision Box
About: Hey there,I'm Aryan,I like to make electronics projects which in the end comes out as videos on YouTube. Not only this I also cover the theory associated with every project,so that you actually know what you...
In this short video I will show you how to program your attiny85 and with the help of that make your own decision box
Step 1: Link for the Video.
Step 2: Program Your Attiny and the Custom Sheild
Programming your Attiny85 with Arduino UNO as ISP.
Step1:Upload the ISP sketch from examples to your arduino Uno.
Step2:Connect the arduino pins to your attiny85 pins as shown.
Step3:Put a 10uF capacitor across the reset and ground pin.(Make sure that the negative side of the capacitor goes to ground)
Step4:We need to twig the blink sketch a bit,since there is no pin13 on the chip,we just have to change to one of the IO's
Step5:Now choose the board and programmer as ISP.
Step6: Hit upload,there will be some pagel error...so just ignore it
Step 3: Part List for This Project.
Ebay.com
1.Arduino UNO: http://goo.gl/s3uwUU
2.Attiny85: http://goo.gl/RJ5m7z
3.5mm RGB led: http://goo.gl/UHOCmT
4.8 pin DIP IC socket: http://goo.gl/fKi71F
5.Tactile Switch: http://goo.gl/Ws0MzA
6.50mm female spacers:
7.perfboard and screws:
Amazon.com
1.Arduino UNO: https://goo.gl/vWUrgK
2.Attiny85: https://goo.gl/53QCo5
3.5mm RGB led: https://goo.gl/DyTHDO
4.8 pin DIP IC socket: https://goo.gl/lgxGKO
5.Tactile Switch: https://goo.gl/aRdViO
Step 4: Schematic and Code
Make sure am using a common anode RGB led in this case,so the code associated with it as per as the schematic.
Link for the code:https://github.com/aryandec25/Attiny85_decision-box
Step 5: And the Project Is Complete !!
If you liked this video,dont forget to like,share and subscribe.
You can follow me on facebook for updates.
Stay innovative and I'll see you next time.
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    3 Discussions
    What does a decision box do, and how exactly does it work? It looks cool, but I think I'm missing something. Can you explain? Thanks! :)
    When you toss a coin,there is a 50% chance that you can get a head.If head was your choice then you win.Similarly,In a decision box,you get three colours,so there is a 33.33% chance that you can win.
    It basically works on the principle of random function,which gives out random output everytime.
    Ah, that makes sense. I like it!
    Thanks for explaining.
