How to Program a LilyPad Without FTDI Converter
5,096
65
5
Published
Introduction: How to Program a LilyPad Without FTDI Converter
Hello everyone! In this article I will show how to program the Arduino LilyPad without the FTDI converter.
Arduino LilyPad is one of the many Arduino microcontroller family, but with a feature that makes it unique.
The LilyPad board, in fact, can be sewn onto fabric using a common thread in stainless steel.
The low price of only 19 € makes this card very useful to be able to add interactivity and technology to our clothes, shoes, bags, hats and much more.
In this guide we will see how to program our LilyPad without using the FTDI converter that would be worth to buy together.
Our board looks like this:
Step 1: PINOUT of LilyPad
This however is the pinout, ie the scheme that shows all the LilyPad PIN.
Step 2: Remove the ATMEGA328 From Arduino Uno
The material we will need is:
- Arduino UNO (NOT SMD)
- LilyPad Arduino
- 5x Jumpers Male - Female
- USB cable
First of all we will have to remove the ATMEGA328 UNO from 'Arduino using a flat screwdriver or an integrated extractor:
Step 3: Circuit
Once extracted the microcontroller pass to mount the circuit according to the following scheme:
Step 4: Sketch
Just finished editing the circuit connect the USB cable Arduino UNO and let's move on PC more precisely in the Arduino IDE.
In the tab "Tools" select "Card" and select from the list our board, "LilyPad Arduino"
Did what we pass to the code, we will use the simple test sketch that allows us to blink an LED, in particular the LED is already on the board connected to digital pin 13.
Now when you will press "Load" LEDs transmission residing on our Arduino Uno flash and this will mean that our LilyPad is receiving the code we wrote.
Good fun!
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    5 Comments
    Hi. Is it possible to connect sensors to the Arduino LilyPad? Like the temperature sensor, ultrasonic sensor, etc using the analog pins?
    And also, is it possible to interface Bluetooth Module with the LilyPad?
    Hi, i think yes, it works like an Arduino Uno, in the same way
    "Program a LilyPad Without FTDI Converter" with the ftdi chip in another arduino.
    Yes but without the FTDI Converter that you must buy.
    Nice Instructable. Thanks. This is quite clever if you happen to have an Arduino UNO laying around which many do. It would also work for most earlier Arduinos. On the other hand if you don't have an Arduino or clone with a socketed ATMEGA an FTDI would be cheaper than buying an Arduino just for this.This is a good option to keep in mind.
