How to Propose - TTE (Time Travel Edition) by gmjhowe
Featured
Step 3: Creating the Ring Box (part 2)
I needed a section to fit the ring into. So i brought forth more card, i cut out 7 pieces of card, and stacked them up to make a little block. I measured the ring, and roughly worked out how big the slot needed to be.
I took my trusty dremal tool again, this time i used a rotary cutter attachment.
With it being made from card, i easily cut out a grove for the ring to sit in.
Next i took a piece of leather, and wrapped it around the block of card. Once wrapped around i could then feel where the slit was, and carefully cut out a hole using an scalpel.
This block then slots into the metal 'box'.
Finally, i coloured the card using a sharpie black marker, i could of easily spray painted it, but, i knew it would be a pain masking it off.
Once coloured in, i then dry brushed a little bit of metallic paint onto the lid.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
