3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Re-Seal the Bead on a Flat Tire The Fun Way!
So here's the situation, your driving down the road in the middle of nowhere, and somehow the tire falls off the bead. All you have is your lighter and a can of starting fluid. Here is how to fix it.
Step 1Materials
Materials
All you need is:
Starting fluid
A lighter
common sense
8 comments
Dec 31, 2009. 9:39 PMheadache2000 says:
I worked on the Alaska oil pipe line and I met  a guy who repaired the BIG AND I  MEAN REALLY BIG TIRES USED ON LARGE EARTH MOVING EQUIPMENT  He  said they used this method on them. He also said that they would use large sheet metal screws to make temporary repairs  on damages that were made by rock cuts in the tire.  He'd just screw a large screw  (1/4 in or larger diameter) into it and then add air. Eventually they would have a large amt. of screws in it or had too large of a hole to fix with the screws, and then they'd take the tire off the rig put on another and go back to the shop (possibly 100 or degree's or more  warmer than outside temps)  then break down the tire and fix all of the holes where the screws were...........................  Truth is stranger than fiction........
Oct 5, 2009. 5:57 PMArbitror says:
Flame travels into canister, canister explodes. You hand is now hanging by bits of tendon and bone.
I don't think I'll take that risk!
Sep 3, 2009. 9:47 PMtrailleadr says:
dangerous, but effective.
Mar 5, 2009. 7:42 PMJack A Lopez says:
Wow! That was awesome!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:Thelonelysandwitch
I like fire
