How to Read Resistor Color Codes
181
Posted
Introduction: How to Read Resistor Color Codes
The following information is a single lesson in a larger project. Find more great projects here.
Return to Previous Lesson: Writing the Code
Lesson Overview:
Now we'll learn how to decipher resistor colors!
Step 1: Colored Stripes
Resistor values are marked using colored bands, according to a code developed in the 1920s, when it was too difficult to write numbers on such tiny objects.
Each of the 4 or 5 colored bands corresponds to a number, like you see in the table.
In the 4-band type, the first two bands indicate the first two digits of the value while the third one indicates the number of zeroes that follow (technically it represents a power of ten). The last band specifies the tolerance: in the example below, gold indicates that the resistor value can be 10 k-ohm plus or minus 5%.
  1. Study the resistor color code diagram. Look at the 10 k-ohm resistor on the breadboard - do the stripes match up with this code?
  2. Continue to the next step.
Step 2: Resistors in Your Kit
Sort through the resistors in your Arduino kit - they have the values listed below. In the simulator, you have access to many more values in between!
220 ohms
560 ohms
1 k-ohm
4.7 k-ohms
10 k-ohm
1 M-ohm
10 M-ohm
  1. Continue to the next lesson to learn how to make your Arduino kit look like a spaceship dashboard.
Next Lesson:Spaceship Template
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
