How to Rebuild Crank Brothers Acid Clipless Bicycle Pedals
 by drew.adc
This instructable will detail how to rebuild a set of Crank Brothers Acid pedals.  Note that this instructable is for the version of the pedals with loose cup and cone bearings.  I bought a used pair of these pedals on eBay along with a couple pairs of cleats.  When I received the pedals, they were in serious need of a rebuild before use.  After doing some searching on the internet, I found that Crank Brothers sells rebuild kits and instructions on how to rebuild those versions of the pedals that come with cartridge bearings but I couldn't find anything on the loose bearing kind.  This project is a fairly simple task to undertake.
Please note however that I am in no way responsible for what you do with or what happens due to this instructable or anything left out of it.  Undertake it completely at your own risk and only if you are comfortable with a project of this type.  If you fail to get the pedals back together correctly, they could fail while riding potentially causing a serious injury, crash, or both.  If anything looks worn out or you are in anyway uncomfortable taking this risk into your owns hands, seek a professional.
Step 1: Tools/Parts You Will Need
Torque wrench with appropriately sized socket for the nut inside of the end cap.  In my case that was a 9mm socket.
Tweezers.  These really help reach into tight places and handle the loose balls from the bearings.
Hex wrench that fits in the spindle.  You will need this to remove the pedals from the bike and to take the spindle out of the pedal body.
Grease.  I chose to use Phil Wood waterproof grease.  It is kind of expensive, but the best grease I have found.
Small screwdriver to pry out the end caps if like mine, yours aren't threaded.
Loctite.  This isn't necessarily a requirement, but I chose to use it for added security from the pedals loosening over time.
Rag. Good to work on so your work surface stays free of grease.
Degreaser. You need something to get the old grease out/off of the existing parts.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
