How to Recover Data From a Dead Computer
Published
Introduction: How to Recover Data From a Dead Computer
About: I have a passion for DIY and love to fix just about anything. Join me in my mission to learn to do it all out here on our new Michigan Farm.
Most people don't know that there is a way to get your files from a dead laptop or desktop computer. It is a horrible feeling when your computer won't start up and you can't get access your photos, or that important paper, tax document, or business presentation. In this video I show you a simple way to get the data directly from the hard drive and onto a working system.
Step 1: Step 1 - Gathering Tools
The first step in the process is to pickup the correct adapter to be used with your hard drive. There are a couple options for this that I have listed here. Once you have the correct universal data transfer cable or hard drive enclosure you are ready to get started.
Data Transfer cable - This is a universal cable (works with any hard drive) that I recommend having on hand BEFORE you have a computer crash.
Hard Drive Enclosures - These are handy since you can use the recovered hard drive as an external backup drive after you recover the needed data.
Laptop SATA Hard Drive Enclosure
Laptop IDE Hard Drive Enclosure
Desktop SATA Hard Drive Enclosure
Desktop IDE Hard Drive Enclosure
Step 2: Step 2 - Removing the Hard Drive
Remove the side panel of the desktop computer or locate the access panel on the bottom of the laptop. Locate and remove the hard drive from the computer using either this video tutorial or the manufacturers guides. On a desktop computer the hard drive is normally located in a small "rack" or metal bracket close to the front side of the computer. In a laptop the hard drive should be accessible from a small access panel on the bottom. This should be labeled with a hard drive icon or the acronym HHD.
Once you have located the hard drive you may have to take it out of a proprietary case or sheath. This is normally accomplished by removing a few screws along each edge and then sliding the hard drive out of the holder. Once the drive is out you are ready to get things connected.
Step 3: Step 3 - Connecting Cables
Connect the universal data transfer cable to the hard drive or insert the hard drive into the appropriate hard drive enclosure. There are two main types of hard drive connection options for both laptop and desktop computers. The older of the two will be an IDE type connection with a group of small pins used. The newer of the two will be a SATA type connections. The newer SATA connection is the same for both desktop and laptop computer hard drives. However the older IDE type connection has a desktop version and a laptop version so keep this in mind when selecting a hard drive enclosure (if you chose that option). Once you have the correct cable connected or correct enclosure you are ready to get plugged into a working computer to transfer your data.
Step 4: Step 4 - Connect to a Working Computer
Connect the hard drive to a working computer. This should be done in order of connecting the power cable for the drive first and then connecting the cable or enclosure to the working computer. Once the drive is connected you should here a noise representing the connection and then you can move onto the computer to start transferring the data.
Step 5: Step 5 - Gaining Permissions
Open your "computer" or "my computer" window and look for a new hard drive listed. You should see something listed as "local" or "HP, Acer, Dell, etc." This will be the connected hard drive. Click to open the hard drive to view the file structure. You may get a message asking to grant yourself permission to view these files. You will need to click "ok" to allow yourself permission and this process might take awhile. Be patient, go grab a snack and come back to check on it but do not interrupt the permission dialog.
Step 6: Step 6 - Transferring Data
Look for the "users" folder. If you are using Windows XP look for "documents and settings". Open this folder and then locate your user name. If you had multiple users you will want to copy all of the user accounts over to the working computer. All of your personal files are located under your user account folder. If you open the folder you can see the categories such as music, documents, pictures, etc. You can copy individual folders or files from here or just drag and drop (or copy and paste) the entire user account folder onto your desktop. This will start the process of copying the data to your working system. If you have a lot of data this process could take some time.
Step 7: Step 7 - Finishing Up
Once the data is done copying you can then disconnect the hard drive from the working computer. At this point you have a couple of choices. If you are going to get the broken computer repaired, put the hard drive back into the computer and take it in for repair. If you are not getting the broken computer repaired then you can save the hard drive in a safe place as an extra backup of your data or use a hard drive enclosure to use this hard drive as a backup device for your files.
I have a full video walkthrough of this entire process here
For more videos, DIY projects, and how-to's check us out at www.simplesuburbanliving.com
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    2 Comments
    Nice tutorial. Just a quick tip. If you want to make the video easier or people to see, you can embed the video on the page using the Embed Video tool in the step editor. Then people will watch the video right on the page.
