Introduction: How to Recover Data From the Hard Drive of a Dead Laptop
Picture of How to Recover Data From the Hard Drive of a Dead Laptop
When a computers dies due to a software failure rather than a hardware problem, its files remain inaccessible but intact on the hard drive. To recover data from the hard drive of a dead Windows, Mac, or Linux notebook, follow one of the methods below.
Step 1:
Picture of
Step 2: Turn Your Old Hard Drive Into an External Hard Drive (Windows, Mac, Linux)
Picture of Turn Your Old Hard Drive Into an External Hard Drive (Windows, Mac, Linux)
Get a hard drive disk enclosure. This is an external system into which you can place a computer’s hard drive in order to run it on another computer via a USB port; essentially, the enclosure will turn your laptop’s hard drive into an external hard drive. Different computers use different hard drive models, so be sure to check your dead laptop’s specifications before making this purchase. Ex. If your laptop has a 2.5 SATA drive, you will need a 2.5 SATA USB enclosure.
  • Unless you have a SATA drive, be sure to buy a laptop-sized disk enclosure; only SATA-ready enclosures can accommodate both desktop and laptop hard drives.
  • Note that disk enclosures aren’t commonly found in big-box stores and are usually purchased online.
Step 3: Borrow a Working Computer That Is Compatible With Your Old One.
Picture of Borrow a Working Computer That Is Compatible With Your Old One.
If you had a Windows, use another Windows; if you had a Mac, use another Mac; etc. Make sure it has enough space to accommodate the files you want to recover from the dead laptop; alternatively, you can hook a second external hard drive up to the working computer and simply use the computer as a transfer system for the files.
  • A Linux computer will be able to read files off of a Windows computer (but not the other way around); unless you understand both systems, however, it is best to use a Windows computer to recover a Windows hard drive.
Step 4: For MAC Users
Picture of For MAC Users
Mac users can insert a Windows hard drive into their computer and be able to read (not write) the contents of their hard drive if they did not install a separate driver, for example NTFS-3G or Paragon NTFS. Take caution, though, and only use Disk Utility during the process to "mount" the hard drive. Any other action you make on Disk Utility may remove contents.
Step 5: Remove the Hard Drive From the Dead Laptop.
Picture of Remove the Hard Drive From the Dead Laptop.
Turn off the laptop, unplug it, and remove the battery. Turn it over and you’ll see that various sections of the laptop base can be unscrewed and removed separately. Either look up your laptop model online to see exactly where the hard drive sits or simply look for the most likely candidate: though it differs between laptops, a laptop hard drive is often similar in size and shape to a 3.5-inch floppy disk. Unscrew the hard drive cover and remove the hard drive. Some models will pop upwards, some will slide outwards, etc.
MikeJhons0n (author)2017-05-18
great guide pal, thanks for sharing
Swansong (author)2017-04-06
Thanks for sharing :)
About This Instructable
316views
7favorites
License:
Bio: simple man
More by MikeJhons0n:How to Recover Data From the Hard Drive of a Dead Laptop
Add instructable to:
