How to Recover Deleted or Lost Photos From Android Internal Memory
Published
Introduction: How to Recover Deleted or Lost Photos From Android Internal Memory
Losing fatal picture from android internal memory would cause so much trouble and grief. As images may carry cherish memory or important information. Thus, if you lost images that stored at android internal memory, finding a way to recover pictures from android internal memory would be priority. In this article, you will learn the best way to recover pictures from android internal memory with full details. That is Jihosoft Android Phone Recovery, which can help you restore pictures, contacts, video, music, Whatsapp chat, Viber messages, etc from Samsung, HTC, LG, Sony, Huawei, etc. Read on to understand more.
Step 1: Download and Launch Jihosoft Android Phone Recovery.
Make sure that you download the compatible version for your PC.
Windows version: recover data from android
Mac version: recover data from android on mac
Step 2: Select Photos to Scan
After you run the app, click “Multimedia” at the interface. it will pop out a window of file type. You can opt photo format that you need to scan. If you don’t remember the format of lost photos, just tap “all photos”. After selection, hit “Next”.
Step 3: Connect Android Device to Computer.
After connect android device to computer via USB cable, turn on USB debugging at android device. After connecting, the app will identify your device. If the app recognize your device, tap "Start" to continue. If the app fails to do so, download related USB driver.
Step 4: Scan Android Device and Preview Lost Photos
The app will start to scan android device after you tap “ Start”. You will have to wait a few minutes till the scanning process is done. After scan, you will be able to preview all the listed pictures.
Step 5: Recover Photos From Android Internal Memory.
Mark those photos that you want, then click “Recover”, your pictures will be stored at computer in a while.
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    2 Discussions
    Actually, I myself have also had such a problem. Later, I learn that internal memory does not mount as a drive like external memory does and that usually Android recovery tools can only restore things from mounted memory location—SD Card. But, Android Data Recovery can easily solve it. My phone is Samsung Galaxy S6, based on Android 4.4 though I assume this should work for most Android phones of most Android OS's, including Android 4.4 and 5.0. In addition, to recover data from iPhone, you can choose another tool named iPhone Data Recovery.
    Requirements:
    1.Android Data Recovery, which is a professional program designed for retrieving lost contacts, messages, WhatsApp history, pictures, music and videos from Android internal memory and also external memory.
    2.A USB cable.
    3.A computer (This app also has a version for mac. Since the process is more or less the same as in Win7, I will only do it under Windows.)
    You can also try this:
    http://www.recovery-whatsapp.com/whatsapp-recovery...
