For more Mac Repair guides as well as replacement parts, visit:
http://www.powerbookmedic.com/mac-repair.php
Remove these ads by
Signing UpStep 1
1.) Go to file menu and choose the eject cd option. (You can also use the keyboard shortcut Command-E)
2.) Drag the disc to the Eject icon on the dock.
The non Common Sense Methods
3.) Open disk Utility (In the Utilities folder in the Applications folder.) Click on the drive, and then click Eject CD in the application window.
4.) Open up Terminal (Again, you'll find this in the Utilities folder in the Applications folder) and type drutil tray eject
5.) On a Macbook, Macbook Pro, Powerbook, or iBook, hold down the trackpad clicker while the machine boots up. This will force an eject.
6.) Hold down the option key while the machine is starting up. This will put you in the disk selection window. At this stage, you can hit the eject button on your keyboard to eject the cd.
If none of these methods work, your drive is likely defective and needs to be replaced. You still can recover your cd, however you'll have to open your machine and remove the drive to do it. You can use our other mac repair videos to determine how to remove the drive from your machine. Then you can use our video and the pictures in this Instructable to disassemble the drive and recover your CD.
Add Comment
