DIY Zippered Dress to Skirt Refashion
Published
Introduction: DIY Zippered Dress to Skirt Refashion
About: Obsessed with all things nautical. O_O Not sure if I'm intensely creative or too lazy to do things the conventional way. :P
So last week I was derping around shopping for a skit costume and came across this goofy looking dress. I loved the skirt however so I bought it and decided to chop off the top and make a skirt out of it.
Step 1: The Dress
So I wanted to keep the original zipper that's in the back but it only came up about two inches above the skirt seam. Which meant I would end up with a small zipper potentially making it difficult to get on. Thankfully It didn't turn out that way. So without further ado here it is.
Step 2: Materials
You'll need:
The dress you want to refashion
Scissors
Pins
Sewing machine
Straight edge or ruler
Fabric chalk
Step 3: Checking the Zipper
Depending on how long your zipper is, you'll need to either measure or eyeball how wide you want the waistband to be and mark it. I wanted mine about an inch or so wide so I marked from where my thumb is about an inch and a half to allow for a 1/2 inch seam.
Step 4: Cutting the Waistband
Make sure the zipper is unzipped and laying closed and cut the top off. Keep the zipper open.
Step 5: The Most Important Step
Every project needs coffee.
Step 6: Check It
Your skirt/dress should look something like this.
Step 7: Pin It
Turn your skirt inside out. Pinning the zipper and getting it even is the most important part. The nature of the dress I had was very tailored. To compensate for the tailoring I had an uneven looking seam when I pinned it. Measure your seam and then pin according to how wide you want your seam allowance. Pin your waistband making sure all the pins are vertical. This will be very important when it comes time to sew.
Step 8: Improvising
While I was pinning I noticed that one of the bodice inseams was coming out. This is easy to fix. I cut off the corners and crosspinned it to keep it in place.
Step 9: Sewing It
Beginning on the pinned zipper, start sewing using a straight stitch. Make sure you go over the zipper part a couple times to make sure it doesnt come out later on. When I came to the crosspinned part I just went over it, backstitched and then went over it again.
Step 10: Finish Up
Turn your new skirt inside out and you're done! Depending on where you want your skirt to lay, you might need to sew darts like I did. I wanted mine to be at my waist and not my hips. For darts, simply fold over the waistband and pin in place like in pictures 2&3. Sew vertically.
Step 11: The Finished Product
Like I mentioned earlier, this project was for a skit costume. My character is a twelve year old girl so I think it will work nicely. Thanks for reading, let me know if it was hepful. Comments are always appreciated!
Step 12:
Step 13:
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Great write up and first instructable! :) hope to see more projects soon
