How to Refill a foaming hand-soap container
This is a method to expand the lifespan of your foaming liquid hand soap (and container).
The foaming hand soap containers in question have a little disclaimer on them stating not to refill them with regular hand soap or they will clog. This is indeed true, however I've noticed a lot of people either throwing away the empty plastic container (what a waste!) or refilling it with regular hand soap, after which they just don't work.
The process is incredibly simple - the foaming pump works because it injects a bunch of air into a small amount of soap as it pumps. Most hand soap is too viscous to accept this air, and it just causes problems. Solution? Make a solution! Water down the soap!
Step 1Choose a soap
Choose a soap
I went with whatever we had around - apple body wash. It's hard to make out in the picture, because of the colour - but I've filled the pump container with about 1/5th soap, then fill to about an inch from the top with water (to prevent overflow when the pump is inserted)
Tip: Add the water slowly, so as to not agitate the soap too much - if it mixes while you're adding water, you will have a hard time getting it to fill without overflowing with suds everywhere.
55 comments
1-40 of 55next »
Jun 10, 2007. 8:49 PMdchall8 says:
I like it. You didn't really get into the economics of this, but the foaming soap refill costs about the same per ounce as the same scent of the non-foaming soap. So when you mix your own, you get about 4x as many handwashings for the money and the same soap scent. I've also used Dawn dishwashing liquid with pretty good results. I mix the soap in a separate container so the foam can settle out. I put about 3 ounces of the hottest water I can into the container first. Then I put the soap in and agitate that until it seems to be mixed but not foamy. Then I slowly fill the container with hot water trying not to generate foam. My process with the hot water might be extra trouble. There is one problem you might watch out for. My first foaming soap dispenser seems to collect soap inside the translucent top. That might be part of the problem with why the plunger isn't working right. I've disassembled and reassembled several times to drain it. If you decide to disassemble your plunger for any reason, THERE IS A TINY STEEL BALL inside. If you lose that critical part, you can recycle or find other uses for the useless plunger parts. Also when reassembling, push on the large plastic cup until it snaps into place. Another possible problem is this. After refilling with a different soap (I used Dawn dishwashing soap in a hand soap plunger), the plunger doesn't seem to move as easily. I switched to refilling with the official brand of foamy soap refill and it works better. I've also tried Wal-Mart's Equate brand of foamy soap refill with good results. I'm trying different things with different plungers and have not really duplicated the problem I had with the first one.
Jan 28, 2012. 11:26 PMloveangel94 says:
I just stumbled across your site. I had a foam soap dispenser and wanted to use some liquid hand soap that my son bought me for Christmas in it. I have seen the dispensers in the catalogs that will let you do that but wanted to see if my foam dispenser from the store would work. It did but not very well. I read your tips here and tried them and now I have a foam dispenser that works with liquid hand soap. Thanks for the wonderful tips. My son is always buying me liquid hand soaps as a gift and love the foam soap. It sure beats paying the price of the foam soap refill. Also I can use other soaps as well. I love the scents you can get with the liquid hand soaps in the different stores especially at Christmas time. :)
Dec 4, 2010. 10:17 AMucanBanerd says:
Thanks for spreading this around, I think buying the refill for these is a waste of money!!! I also use foaming soap dispensers to dilute the face wash i use tha't too strong for my sensitive skin. Also then you can make your hand soap whatever scent you want!!
Nov 20, 2011. 9:30 PMapinkpony says:
Great idea suggesting reusing them for foaming face wash... (have you seen the new bottles than cost $10+ that are made to put your own water/soap combo in? Kidding me? This is so much cheaper!)
Jul 3, 2008. 6:18 PMinquisitive says:
I like to add a shot of rubbing alcohol and mix it all up.
Jul 12, 2008. 8:34 AMPunkguyta says:
Rubbing alcohol FTW! 99% or 70%??
Jul 13, 2008. 12:04 AMinquisitive says:
Either, but if diluting the solution I tend to prefer the 90% is what I purchase; however, the friction and soap removing offending dirt will do the trick anyway. Hand sanitizers are predominantly isopropryl alcohol based with a couple things to make it seem more pleasant. I keep a small mister bottle of isopropryl alcohol at my cubicle for quick cleanups, first aid, and wrinkle remover.
Jul 23, 2008. 7:26 AMmbear says:
Doesn't bleach kill everything? I wonder what would happen if you added a little bleach to the soap. Well, besides messing up your hands as the skin cells die.
Jul 29, 2008. 9:53 PMacer73 says:
It doesn't exactly kill the skin cells unless you soak your hands in there. But it does really dry them out. So you wash your hand to get exsess junk off then you rub some oily lotion back on them.
Jul 30, 2008. 4:49 AMmbear says:
A Ha! So if you mix a shot of bleach into this stuff, it'll kill all the nasties (scientific term) and leave your hands alone. Good to know.
Jul 15, 2011. 10:30 PMekerkow says:
Just washing your hands with plain soap will get them as clean as washing with harsh chemicals. This is a fact that has been demonstrated by peer-reviewed scientific studies. Most of the cleaning action when you wash your hands is the mechanical action- rubbing your hands together and the water carrying dirt etc away- rather than any chemical action. Soap is nice to add for the degreasing effect. Unless you or someone you are in close contact with has a serious immunity problem, regular soap is all you should need.
Oct 22, 2011. 2:04 AMJasonQ says:
Just chiming in here to totally agree with you. Much of soap's cleaning action is in fact mechanical, though soap itself does denature the outer membranes of germ cells, thereby destroying them. Hot water is a good idea too.
Oct 10, 2011. 12:23 PMgbisaga says:
You, sir, are a genius! This works great. I used about 4:1 (Method foaming soap dispenser) and it now works again. Thanks for posting.
Sep 17, 2011. 3:43 PMjwggmn says:
Rubbing alcohol is ok as far as I know...I use it as a non-toxic general bathroom cleaner (but don't drink it, lol)...in the kitchen I generally use vinegar (which you can - moderately)...
Sep 17, 2011. 3:25 PMjwggmn says:
Anti-bacterial's in soaps (or most anything else) are not only ineffective but are terrible for the environment; they get in the water and can kill most anything that grows! Please keep this in mind...
Jun 28, 2011. 1:31 PMstrout says:
Thanks for the tip. I figured diluting it would probably work, but I didn't want to ruin my dispenser experimenting! I will probably use my sample size hotel soaps (that I always collect but rarely use) and add some vinegar to ensure bacteria fighting power. For those trying to go all natural, Castille soap (which I had an hard time finding when I was shopping for materials to make my own cleaning products but eventually located at a natural foods market) would be the eco-friendly route.
Jun 26, 2011. 4:12 PMkzoosoapguy says:
You for sure don't want to add any rubbing alcohol. What you guys are missing is that you are still not even using real soap. When you buy most store bought "soaps" you are just getting chemicals that act like soap but will really dry out your skin due to the lack of glycerin. What you need is some refills made with real handmade soap which contains the type of moisturizers you need. I never understand why people don't learn about things they put in or on their body. We are putting up a new line of "refill only" foaming soaps at http://www.handmadesoapbar.com This way you can save money on not paying for the bottle, which in most cases is the most expensive part of buying more soap
May 20, 2011. 10:37 AMFoamSoap says:
We supply foam soap pumps with empty bottles.  Users of theis site can take 10% off with your first order.
Enter coupon code: " instructables " at checkout.
http://www.bottlesandfoamers.com
Thank you. Kevin
Oct 24, 2010. 8:22 AMjanwinje says:
Thanks for the foaming soap idea, I should've known that! To ease your minds about bacteria, I bet a tablespoon of white vinegar added to the mix will solve that problem.
Aug 31, 2010. 4:48 AMwetnap says:
Yea i've been doing this for a while, it wastes far less soap as most of the regular dispensers dispense a ridiculous amount of soap that coats your hands in a thick layer of goo, meant mostly to hasten purchase of more soap, its not economical, or environmental, and i find that it takes longer to wash off the goo and leaves more residue on your hands. i love these new foaming dispensers, brilliant idea.
Jul 14, 2010. 2:53 PMmomof2inflbaking says:
The instructions are perfect!! The measurements don't have to be exact. An approximate 4:1 ratio works fine. I recently purchased clear foaming dispenser bottles from eBay after my fancy liquid soap dispenser broke. Bed, Bath, and Beyond doesn't even carry a foaming dispenser bottle. And I didn't want anything to mount on the wall. So, following the directions, I now have a foaming soap dispenser. Since the liquid soap I have in the house was the large commercial size, it may be over a year before I have to purchase more liquid soap!!! To those who commented that refilling a foam dispensing bottle is more work then it's worth, I have one word -- LAZY! I followed the instructions & was done in less than a minute.
Dec 15, 2009. 9:28 PMFooGlacticon says:
Great instructable, but "more work"? Really? It would be harder for me to find somewhere to store a 4L container.
Pour, fill, shake, done. Twenty seconds, max. I'd probably take more time walking down the aisle to get a new dispenser. ;)
Jul 3, 2008. 7:44 PMtyler durden says:
Antibacterial-soap is BS. All antibacterial agents take time to kill the bugs, a lot more time than the soap will be on your hands. I don't care if the soap kills bugs in the drain, do you?
Jul 3, 2008. 9:29 PMalex-sharetskiy says:
The problem is that the antibacterial crap will go to the waste treatmebt plant, and kill the bacteria that is eating your poop, lol no, there is no bacteria eating your poop, it gets seperated, then burned/buried BUT there is bacteria that breaks down Amonia in your urine, and killing it isn't that good
Nov 1, 2009. 6:13 PMbwpatton1 says:
Actually your wrong on one fact there, there is a bacteria that breaks down your poop, it breaks down the solids then the dead microorganisms are sent to a landfil (I think)
Source:My dad works in water/waste water
Jul 8, 2008. 11:00 AMNilhilustfrederi says:
What better place for resistant bacteria to evolve than in a sewer? Not too cold, lots of different kinds of antibiotics, and plenty to eat.
Jul 8, 2008. 1:29 PMalex-sharetskiy says:
Bacteria doesn't have enough time to evolve, it would take countless generations of bacteria it CAN happen but the chances of it happening are low
Jul 9, 2008. 5:11 AMNilhilustfrederi says:
Given bacteria's short lifespan and fairly high attrition from all the antibiotics, I don't think it would be very unlikely for at least a mild resistance to develop. In places where sewage is baked and turned into fertilizer, it wouldn't matter much, but it's not uncommon for sewage to just be pumped out to sea.
Jul 9, 2008. 9:01 AMalex-sharetskiy says:
that's pretty rare in the US but in places like India, ya
Jul 3, 2008. 5:41 AMcowscankill says:
sweet. could you make anything else foam with this?
Oct 29, 2009. 7:00 PMsleeepy2 says:
I'd like to try a ketchup foam....
Nov 3, 2008. 9:18 AMMichaelW says:
It works! Thanks.
Jul 4, 2008. 9:33 PMtyler durden says:
Flu is caused by viruses, not bacteria. Antibacterial soaps use detergents that dissolve the cell walls of the bacteria. Unless the bacteria evolve a completely different cell wall, the antibacterial stuff will continue to work. Antibiotics work by interfereing with protein synthesis or other mechanisms that ultimately prevent bacteria from reproducing faster than your immune system can clear them. They can evolve mechanisms that either prevent the antibiotic from working (in the case of penicillin resistance) or eliminatingor modifying the target molecules. Antimicrobial soaps DO lead to skin problems if used frequently.
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:frollard
In a world where the blind leads the blind, who do you follow?
