How to Refoam your Woofer
During the seventies and eighties, either planned obsolescense, poor engineering, or short-sightedness caused speaker manufacterers to use a type of rubber surround for drivers that deteriorates with age. Perhaps you have a pair of speakers that show the classic grainy, dirty looking speaker surrounds or maybe even have holes in them already. I got a pair of old Advent Heritage speakers from a guy for free because the surrounds were shot. The previous owner tried using silicone caulk to stave off the inevitable to no avail.
For about ten bucks a driver, you can replace the foam surrounds if you have some patience and determination.
There was a time when the quality of a manufacturer's equipment was what determined their success, rather than the amount of money they spend on advertising. While those days are past, much of this aging Hi fi equipment can be found on craiglist or freecycle for a song. At best, they are ready to go with a little dusting. Sometimes, however, the drivers need to be refoamed. Would you like to get started?
Rock on!
Step 1Stuff to get:
Stuff to get:
Obviously you will need an old pair of speakers. The foam surround kits are not inexpensive so make sure you are getting a decent pair of speakers to begin with. Also the paper cones should move freely and they should still make sound when played. All the drivers should play. If they have been energized a lot with the surrounds damaged, the voice coil could be abraided away, shorted out, etc. Those should be avoided because I don't think that's an easy fix. Today we are working on a pair of Advent Heritage speakers. They are not the classic Advents and were produced after Jensen bought the company and ruined it. However these speakers, despite, their shortfalls, sound really good to my ears. The cabinets are pecan and clean up really well.
Materials:
Screwdriver
Razor blade, hobby knife, or scalpel
Stiff brush or toothbrush
Can of air
Speaker refoam kit http://stores.ebay.com/GeoAli-Vintage-Stereo-and-More
The kit I purchased included the glue, paint brushes, shims, speaker edges, and instructions.
Wood care products of choice (I'm using Howard's Restore a Finish and orange oil cleaner)
Clamps, c-clamps or the like if you have beauty rings to clamp into place.
Hair dryer or heat gun if your speakers have vanity rings around the basket ring.
32 comments
Jan 2, 2012. 4:45 AMchamunks says:
Well thanks for the Ible I have about 4 pairs of some ultra fantastic somethings that i cant recall the name of as of right now but in their day they were absolutely boss at cranking out the acoustical joy.
Dec 31, 2011. 5:02 PMnurdee1 says:
On your first picture in your first step you have some of your picture note boxes inside others. Because of this you can't read the notes in the inner boxes.
Dec 5, 2011. 3:02 PMbr7930 says:
Great Job
Thanks
Beauty rings ---again
After I refoam I put the rings back on covering the edge of the foam where it was glued - correct.
It looks like they hold the foam in place - but I know its the glue.
BR
Dec 24, 2010. 1:04 PMflame boyyyy says:
love the dog picture lol ugly woofer foam
Dec 5, 2010. 9:48 AMrippa700 says:
Brilliant instructable thanks. I was about to abandon an old 1970's pait of Boston Acoustics that have knackered foam. They have sat unused for 4 years since I saw the damage as I couldn't bear to part with them. Now I don't have to. Thanks.
Sep 3, 2010. 1:15 PMhell_raiser_1 says:
Is it plain white glue?? or theres something special about it?? I say this because I need to refoam a pair of 10" infinity's and I can buy the foam for 4 bucks each!!!
Sep 5, 2010. 11:59 PMhell_raiser_1 says:
Exactly !!!!!!, I did some testing with an old piece of foam, clear drying-yellow glue (which is exactly the same as the finest Elmers but with a higher viscosity), and glue it to a metal and I couldn't believe my eyes, I wasn't able to take it apart without tearing out the foam. Great Instructable !!!!!
Jun 16, 2010. 6:52 PMHomibeef says:
You got lucky that only the foam was shot. Heritages are nice speakers. Good tutorial too.
Jan 12, 2010. 11:28 PM3VIL G3NIUS says:
 i believe they used foam because then the driver would not require any breaking in like rubber does... nice instructable! never heard of anyone calling them beauty rings though.
Jan 17, 2010. 5:16 PM3VIL G3NIUS says:
 no probs, im happy to comment :-).
i dont know what they are called either. not many speakers have them now (not the cardboardy one anyway) i dont think they even have a official name so beauty rings they shall be :-)
Oct 8, 2009. 1:07 AMbobbyrae says:
Beauty rings?  Not exactly sure what is meant by that.  I can see what you are doing with them, but I would like a definition, and, can they be bought somewhere?
Aug 26, 2009. 11:07 PMsibuadvancetech says:
good information for the speaker and keep up your good work
Dec 22, 2008. 1:24 PMZak says:
My woofers had the dust cap integral with the cone (Dynaudio). The instructions that came with my surrounds told me to glue the rings to the cone first. After that, the foam would be clamped to the frame with 4 clothespins. Then, testing by pushing on the cone. By off-center pushing it can be determined that the voice coil is centered (scratching starts at the same amount of off-center-ness). Then the glue is applied where clothespins are not. When that dries, the clothespins are removed and the remaing bits glued on.
Aug 17, 2009. 4:54 PM70scollect says:
Hello Foxtrot, Please reply to the PM I sent you. You appear to have the know how to fix these. I really need help and advice on a Advent 1000A repair project I have. Thanks for any help!
Aug 11, 2009. 7:32 PMYerboogieman says:
What if you have steel dust caps with Really good adhesive and will not cut? And even harder to put a knife under to peel off. They are indent caps.
Jun 27, 2009. 11:10 AMdz0004455 says:
if i only need to refoam the edge do I have to remove the dust cap and the foam or just the foam?
Mar 30, 2009. 1:14 PMjac hawk says:
fantastic very very very helpful
Mar 19, 2009. 5:15 AMGuitar_slave says:
Great instructable thanks man i have searching for this cind of instructable for a long time TNX. good work
Mar 7, 2009. 7:24 PMfsm1982 says:
I am looking for this at years... You save the world! =D
Jan 4, 2009. 9:10 AMdan2 says:
if the crossovers are old it would be a good idea to replace the caps - caps lose their capacitance after a while and this changes your crossover frequency.
Jan 22, 2009. 7:12 AMFoxtrot70 says:
dan2 - Your absolutely correct about the caps. I rebuilt 3 Advent Video Beam 1000A projection tv's since the units were built around 1978 the cap values changed so much circuits like focus, AC filtering on the main power supply were all most useless. It was expensive replacing them but the final result is a tv with a 8' screen, it can also be converted into a rear projection of two sizes 8' and 10'. They are a joy to watch everything is as big or bigger than life.
Jan 21, 2009. 6:58 PMkelraith says:
What breed of dog is that on the left?
Dec 22, 2008. 3:33 PMjunits15 says:
Nn interesting repair technique is if the paper on the speakers is ripped, some clear or black nail polish fixes it, I've done this many times and it works with no decrease to quality. This actually works believe it or not! (BTW I'm a guy don't ask questions!)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:emergencydpt.com
