How to Remove Marker Damage from Furniture
 by sosclosetsandfurniture
Featured
From time to time everyone has had accidental marker or pen marks on furniture.  The furniture I am currently working on belongs to a mom with three small children.  There are a lot of marker scribbles!
Step 1: Supplies Needed
The materials you need are:
laquer thinner
soft cotton cloth
steel wool (###) in the example  depends on the project
sand paper
elbow grease
sosclosetsandfurniture (author) says: Feb 5, 2013. 10:46 AM
Hi
It's possible. The Laquer thinner is strong stuff. You would not want to expose the surrounding finish to it. It's always best If you can test it on an inconspicuous spot. When ready, you might try it with a Qtip, very sparringly, following the vase outline a little at a time, a small section only. Follow with another dry Qtip almost immediately. Don't wipe with a rag as you will inadvertantly smear laquer thinner on the surrounding surface. A ring shape is so distinctive. It's hard to work with and not remain a little noticable. If the finish is very durable you may be able to apply a little elbow grease. Let me know if you have any other questions!
DaveBilling says: Feb 5, 2013. 7:33 AM
Do you think this technique will work with a dye that has transferred from a vase on to a table top ? Use the same materials to clean ?
Thanks Dave
natalie_anderson says: Sep 1, 2012. 2:46 PM
My kids have used waterproof marker, will this work for that aswell, or do you have any other tips? My kids don't normally have access to waterproof markers, unfortunately their friends do!!lol:)
sosclosetsandfurniture (author) in reply to natalie_andersonSep 1, 2012. 6:33 PM
These were everything, marker pen crayons. Should work for you Just be super cautious putting on the laquer thinner. Test a spot somewhere not noticeable incase it might damage your finish. Hope it helps!
jessyratfink says: Aug 4, 2012. 10:34 AM
This is great. I didn't know if was so easy. :)
sosclosetsandfurniture (author) in reply to jessyratfinkAug 4, 2012. 1:08 PM
Thanks for the comment. It really works great. Just be careful to test for compatibility.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
