3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Remove and Replace a Weslock doorknob
I have an older home, and found a Weslock door knob on one of my doors that I wanted to swap out with a locking knob made by Defiant. At the local Home Depot, the only two brands of knobs that I saw were Defiant and Keystone. I don't know if Weslock still exists, it might be rare. I attempted to remove the Weslock knob, but to my frustration I could not figure it out.
Google is your friend, right? A quick search for how to remove this knob came up nil. I came across a forum that vaguely spelled out how to remove this. I think a step by step guide with pictures would help. It annoys me how vague a description is. When someone asks how to do something, don't give them a vague answer assuming they know what certain technical terms are. Define things, or at least show pictures. Well, here is the guide to removing a Weslock knob that I encountered (non-locking, no key). It's straightforward, you just need to locate where the secret elements are.
Step 1Remove the side plate
This is where you see the "Weslock" name. There's two philips screws to unscrew, and then you can pry it out. However, underneath is something that looks like another plate. This is permanently affixed, so don't bother removing this. I found that out after viciously trying to pry that off!
10 comments
May 6, 2012. 9:49 PMcfvth says:
You can buy doors and windows at >:=0
Aug 18, 2010. 6:24 PMwilliamson says:
Thank you for your clear instruction; it was helpful. I discovered something on my attempt to reassemble that perhaps should be added. After I reassembled, I discovered that the lever was effective in only one direction. I inspected a second unit and noted notches on the top and bottom of the latch body that must engage the wings on the lever assembly. When inserting the first lever (or knob), I had not engaged the wings in the notches. As a consequence, the lever would only engage the latch when rotated counter-clockwise. When I repeated my assembly I made sure to engage the wings in the notches and the set worked as expected.
Feb 14, 2010. 2:05 PMKrish_H says:
Thank you so much!!!!  After struggling with my weslock door handles for quite some time, this step by step assisted me to remove my weslock door handles in about 1 minute!  Would have never looked for the "secret" tiny button to be the key to remove the knobs.  Thanks!
Feb 11, 2010. 11:27 AMknexfan9182 says:
You helped me escape my bedroom.
Sep 26, 2009. 2:18 PMTvadon says:
I LOVE GOOGLE!!!! OH, and the people who contribute! You helped me crack the Wesgate door knob safe LOL.
Aug 22, 2009. 6:25 PMjoetheaccountant says:
Thanks so much for posting this. It helped me to not destroy the door. It also made my wife very happy as I had been avoiding this task for awhile...
Aug 1, 2009. 10:35 AManntal says:
Thanks so much - our home is 50+ years old and I knew if I went to the internet someone could show me how to do this!
Jul 4, 2009. 8:10 AMcynharts says:
Thank you! thank you! thank you!! I purchased a new lock to put on my home entry door thinking it would be a breeze since I have put locks on doors before. Much to my surprise I discovered the lock on my door didnt have any visable screws for me to take if off the door. Quick search on the internet brought me here to discover I had this particular lock that had a relese tab to pull the knob off and then the screws were there! 4th of july too and I was begining to panic about leaving my door lock half mangeled from me trying to get it off the door. This site was a life saver!! Now off to see the fireworks! Thanks again!
Apr 30, 2009. 4:02 PMwickedsmack says:
This helped a bunch man, I was about to pull the whole darn thing and with a crow bar and burn the door. Great instructions and great pictures, thanks again!
Mar 16, 2009. 2:46 PMwcrr says:
Thanks! I've been looking all over for just these instructions.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:fuzqo
