3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Repair Automotive A/C
Step 1Freon check
freon check
You will need a set of manifold gauges to check you freon pressure.
Here are some general guideline for A/C system pressures and temperatures based on ambient outside temperature. Remember that these are a guideline and your actual temperatures and pressures will vary depending on humidity in the air and the condition of your system. When running the car at idle to check the freon level it is a good idea to have a water hose handy and spray water on the a/c condencer. The condencer is located in front of the radiator.
For vehicles currently running with freon R-134a only
Outside-----low side-------High side------Center vent temp
60 F -----28-38 psi----130-190 psi ----44-46 F
70 F ------30-40 psi ---190-220 psi ----44-48 F
80 F ------30-40 psi ---190-220 psi ----43-48 F
90 F ------35-40 psi ---190-225 psi ----44-50 F
100 F -----40-50 psi ---200-250 psi ----52-60 F
110 F -----50-60 psi ---250-300 psi ----68-74 F
120 F -----55-65 psi ---320-350 psi ----70-75 F
_
You can also use this good rule of thumb with R134a, run fan on High with all windows open and engine at 1500 rpm. High side pressure in PSI should be about 2.2 to 2.5 times outside air temperature in degrees F. Example if it's 90 degrees F, high side should be no higher than 225PSI
Here is a useful trouble shooting chart for systems currently running on freon R-134a
Trouble shooting
Low Compressor Discharge Pressure
1. Leak in system 2. Defective expansion valve 3. Suction valve closed 4. Freon shortage 5. Plugged receiver drier 6. Compressor suction valve leaking 7. Bad reed valves in compressor
Repair
1. Repair leak in system 2. Replace valve 3. Open valve 4. Add freon 5. Replace drier 6. Replace valve 7. Replace reed valves
High Compressor Discharge Pressure
1. Air in system 2. Clogged condenser 3. Discharge valve closed 4. Overcharged system 5. Insufficient condenser air 6. Loose fan belt 7. Condenser not centered on fan or too far from radiator
Repair
1. Recharge system 2. Clean condenser 3. Open valve 4. Remove some refrigerant 5. Install large fan 6. Tighten fan belt 7. Center and check distance
Low Suction Pressure
1. Refrigerant shortage 2. Worn compressor piston 3. Compressor head gasket leaking 4. Kinked or flattened hose 5. Compressor suction valve leaking 6. Moisture in system 7. Trash in expansion valve or screen
Repair
1. Add refrigerant 2. Replace compressor 3. Replace head gasket 4. Replace hose 5. Change valve plate 6. Replace drier 7. Replace drier
High Suction Pressure
1. Loose expansion valve 2. Overcharged system 3. Expansion valve stuck open 4. Compressor reed valves 5. Leaking head gasket on compressor
Repair
1. Tighten valve 2. Remove some refrigerant 3. Replace expansion valve 4. Replace reed valves 5. Replace head gasket
Compressor Not Working
1. Broken belt 2. Broken clutch wire or no 12v power 3. Broken compressor piston 4. Bad thermostat 5. Bad clutch coil 6. Low Refrigerant - low pressure switch has cut off clutch power
Repair
1. Replace belt 2. Repair wire or check for power 3. Replace compressor 4. Replace thermostat 5. Replace clutch coil 6. Add refrigerant
Evaporator Not Cooling
1. Frozen coil, switch set too high 2. Drive belt slipping 3. Hot air leaks into car 4. Plugged receiver drier 5. Capillary tube broken 6. Shortage of refrigerant 7. High head pressure 8. Low suction pressure 9. High suction pressure 10. Defective expansion valve 11. Frozen expansion valve
Repair
1. Turn thermostat switch back 2. Tighten belt 3. Check for holes or open vents4. Replace drier 5. Replace expansion valve 6. Add refrigerant 7. See problem #2 8. See problem #3 9. See problem #4 10. Replace expansion valve 11. Evacuate and replace drier
Frozen Evaporator Coil
1. Faulty thermostat 2. Thermostat not set properly 3. Insufficient evaporator air
Repair
1. Replace thermostat 2. Set to driving condition 3. Check for excessive duct hose length, kink or bend.
If you can't get your a/c to turn on then use this chart to determine if you are low on freon. Remember that this is a general char and will very for different makes and model cars and refrigeration units
Temperature -------------------134a Pressure(Psig)
-60.0----------------------------------21.6*
-55.0 -----------------------------------20.1*
-50.0 ---------------------------------- 18.5*
-45.0 ----------------------------------- 16.7*
-40.0 ----------------------------------- 14.6*
-35.0 ----------------------------------- 12.3*
-30.0 ----------------------------------- 9.7*
-25.0 ------------------------------------ 6.7*
-20.0 ------------------------------------ 3.5*
-15.0 ------------------------------------ 0.1
-10.0 ----------------------------------- 2.0
-5.0-----------------------------------------4.2
0----- ------------------------------------- 6.5
5.0 ---------------------------------------- 9.2
10.0 ------------------------------------- 12.0
15.0--------------------------------------15.1
20.0 --------------------------------------18.5
25.0 ------------------------------------- 22.2
30.0 --------------------------------------26.1
35.0 --------------------------------------30.4
40.0---------------------------------------35.1
45.0---------------------------------------40.1
50.0 --------------------------------------45.5
55.0---------------------------------------51.2
60.0--------------------------------------- 57.4
65.0----------------------------------------64.1
70.0--------------------------------------- 71.1
75.0 ---------------------------------------78.7
80.0--------------------------------------- 86.7
85.0--------------------------------------- 95.3
90.0 ------------------------------------ 104.3
95.0--------------------------------------114.0
100.0 -------------------------------------124.2
105.0--------------------------------------135.0
110.0--------------------------------------146.4
115.0--------------------------------------158.4
120.0--------------------------------------171.2
125.0--------------------------------------184.6
130.0--------------------------------------198.7
135.0------------------------------------- 213.6
140.0--------------------------------------229.2
145.0 ------------------------------------- 245.5
150.0-------------------------------------- 262.9
155.0-------------------------------------- 281.1
160.0---------------------------------------300.0
  • - (in Hg) Vacuum
7 comments
Apr 9, 2012. 5:59 AMnlaurence says:
sir, what would be the possible cause of unwanted odor entering the car through the A/C?
Feb 16, 2012. 7:25 PMbchenry says:
Using propane and other flammable refrigerants is illegal in many states and really upsets those who do it professionally, as it contaminates very expensive equipment. Also evaporator leaks can be found with an electronic leak detector at the evaporator drain or by taking out the blower motor resistor and checking through there (dye often will show up there as well).
Recovering hoses is also required by law if the hose is longer than 1foot.
Also the EPA license to buy R12 is really easy, its an open book test and can be taken through ASE.
Dec 4, 2011. 8:49 AMahooper says:
A good friend of mine worked for a refrigeration company and after talking with the engineeers replaced the gas in his AC unit with Propane. worked pretty well apparently and real cheap.
Jun 28, 2008. 12:41 AMDerin says:
here is how mechanics find leaks: 1 fill system with nitrogen 2 spray foam all over engine(they did that) if it bubbles you got a leak 3close the leak 4 retrieve freon,seperate nitrogen 5 fill old freon back,add more if necessary
Mar 27, 2008. 8:44 PMMr. Smart Kid says:
relaceing gas type coolent into the ansophere is a goverment offence
Mar 7, 2008. 8:40 PMGorillazMiko says:
Wow... Actually a pretty detailed Instructable, nice job.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ivanbg
