loading
Step 1: freon check
You will need a set of manifold gauges to check you freon pressure.
Here are some general guideline for A/C system pressures and temperatures based on ambient outside temperature. Remember that these are a guideline and your actual temperatures and pressures will vary depending on humidity in the air and the condition of your system. When running the car at idle to check the freon level it is a good idea to have a water hose handy and spray water on the a/c condencer. The condencer is located in front of the radiator.
For vehicles currently running with freon R-134a only
Outside-----low side-------High side------Center vent temp
60 F -----28-38 psi----130-190 psi ----44-46 F
70 F ------30-40 psi ---190-220 psi ----44-48 F
80 F ------30-40 psi ---190-220 psi ----43-48 F
90 F ------35-40 psi ---190-225 psi ----44-50 F
100 F -----40-50 psi ---200-250 psi ----52-60 F
110 F -----50-60 psi ---250-300 psi ----68-74 F
120 F -----55-65 psi ---320-350 psi ----70-75 F
_
You can also use this good rule of thumb with R134a, run fan on High with all windows open and engine at 1500 rpm. High side pressure in PSI should be about 2.2 to 2.5 times outside air temperature in degrees F. Example if it's 90 degrees F, high side should be no higher than 225PSI
Here is a useful trouble shooting chart for systems currently running on freon R-134a
Trouble shooting
Low Compressor Discharge Pressure
1. Leak in system 2. Defective expansion valve 3. Suction valve closed 4. Freon shortage 5. Plugged receiver drier 6. Compressor suction valve leaking 7. Bad reed valves in compressor
Repair
1. Repair leak in system 2. Replace valve 3. Open valve 4. Add freon 5. Replace drier 6. Replace valve 7. Replace reed valves
High Compressor Discharge Pressure
1. Air in system 2. Clogged condenser 3. Discharge valve closed 4. Overcharged system 5. Insufficient condenser air 6. Loose fan belt 7. Condenser not centered on fan or too far from radiator
Repair
1. Recharge system 2. Clean condenser 3. Open valve 4. Remove some refrigerant 5. Install large fan 6. Tighten fan belt 7. Center and check distance
Low Suction Pressure
1. Refrigerant shortage 2. Worn compressor piston 3. Compressor head gasket leaking 4. Kinked or flattened hose 5. Compressor suction valve leaking 6. Moisture in system 7. Trash in expansion valve or screen
Repair
1. Add refrigerant 2. Replace compressor 3. Replace head gasket 4. Replace hose 5. Change valve plate 6. Replace drier 7. Replace drier
High Suction Pressure
1. Loose expansion valve 2. Overcharged system 3. Expansion valve stuck open 4. Compressor reed valves 5. Leaking head gasket on compressor
Repair
1. Tighten valve 2. Remove some refrigerant 3. Replace expansion valve 4. Replace reed valves 5. Replace head gasket
Compressor Not Working
1. Broken belt 2. Broken clutch wire or no 12v power 3. Broken compressor piston 4. Bad thermostat 5. Bad clutch coil 6. Low Refrigerant - low pressure switch has cut off clutch power
Repair
1. Replace belt 2. Repair wire or check for power 3. Replace compressor 4. Replace thermostat 5. Replace clutch coil 6. Add refrigerant
Evaporator Not Cooling
1. Frozen coil, switch set too high 2. Drive belt slipping 3. Hot air leaks into car 4. Plugged receiver drier 5. Capillary tube broken 6. Shortage of refrigerant 7. High head pressure 8. Low suction pressure 9. High suction pressure 10. Defective expansion valve 11. Frozen expansion valve
Repair
1. Turn thermostat switch back 2. Tighten belt 3. Check for holes or open vents4. Replace drier 5. Replace expansion valve 6. Add refrigerant 7. See problem #2 8. See problem #3 9. See problem #4 10. Replace expansion valve 11. Evacuate and replace drier
Frozen Evaporator Coil
1. Faulty thermostat 2. Thermostat not set properly 3. Insufficient evaporator air
Repair
1. Replace thermostat 2. Set to driving condition 3. Check for excessive duct hose length, kink or bend.
If you can't get your a/c to turn on then use this chart to determine if you are low on freon. Remember that this is a general char and will very for different makes and model cars and refrigeration units
Temperature -------------------134a Pressure(Psig)
-60.0----------------------------------21.6*
-55.0 -----------------------------------20.1*
-50.0 ---------------------------------- 18.5*
-45.0 ----------------------------------- 16.7*
-40.0 ----------------------------------- 14.6*
-35.0 ----------------------------------- 12.3*
-30.0 ----------------------------------- 9.7*
-25.0 ------------------------------------ 6.7*
-20.0 ------------------------------------ 3.5*
-15.0 ------------------------------------ 0.1
-10.0 ----------------------------------- 2.0
-5.0-----------------------------------------4.2
0----- ------------------------------------- 6.5
5.0 ---------------------------------------- 9.2
10.0 ------------------------------------- 12.0
15.0--------------------------------------15.1
20.0 --------------------------------------18.5
25.0 ------------------------------------- 22.2
30.0 --------------------------------------26.1
35.0 --------------------------------------30.4
40.0---------------------------------------35.1
45.0---------------------------------------40.1
50.0 --------------------------------------45.5
55.0---------------------------------------51.2
60.0--------------------------------------- 57.4
65.0----------------------------------------64.1
70.0--------------------------------------- 71.1
75.0 ---------------------------------------78.7
80.0--------------------------------------- 86.7
85.0--------------------------------------- 95.3
90.0 ------------------------------------ 104.3
95.0--------------------------------------114.0
100.0 -------------------------------------124.2
105.0--------------------------------------135.0
110.0--------------------------------------146.4
115.0--------------------------------------158.4
120.0--------------------------------------171.2
125.0--------------------------------------184.6
130.0--------------------------------------198.7
135.0------------------------------------- 213.6
140.0--------------------------------------229.2
145.0 ------------------------------------- 245.5
150.0-------------------------------------- 262.9
155.0-------------------------------------- 281.1
160.0---------------------------------------300.0
  • - (in Hg) Vacuum
<p>I believe I have moisture in my car's air-conditioning system. We put freon in and now it will blow freezing air for about 5 minutes &amp; then blow hot air. How do I fix this?</p>
Great instruct able but a few things are off. <br><br><br>A vacuum should be pulled to under 500 microns measured with a micron gauge. Without it your not sure if there is still moisture present in the system or the pump is capable of going that low to get all your non-condensables out.<br><br>Leak testing with a vacuum doesn't mean there is not leak. At most a deep vacuum is only putting 30psi pressure on the outside of the pipe pushing in, and dirt can get sucked into a crevice temporarily stopping any noticeable leaks. R134a can achieve what like a little under 200 psi? If possible use dry nitrogen and fill to 150 psi then wait to see if it leaks. Don't use air and definitely don't use oxygen unless you like explosions.
<p>Yes, you are correct that the best way to check leaks is with 150 to 200 lbs dry nitrogen and wait at least an hour with no pressure drop.</p><p>Checking with a vacuum is even less effective than you state; at sea level the most pressure you will get pushing in from outside is atmospheric pressure, about 14.7psi :)</p>
<p>We got the 12v socket car use air cooling fan from www.amazon.com/dp/B010CESJTC , it helps so much that now we are OK to keep the weak air conditioner now for the summer.</p>
<p>this is the best air con instructable EVER!</p>
Thank you for the very extensive instructable sir. That was probably hard work. Your detail is much appreciated.
I have a 2005 chrysler town and country the ac compressor has a whinning noise, when you start the car.Even when the the ac is off.
<p>its your belt maybe its time to replace it maybe a little bit loose but this almost never happened I fix mine with w40 just spray it to the belt inside and out</p>
<p>Hi I have a ute and the AC works for a short time like 10 / 20 mins then stops, any clues? It isn't freezing up.</p><p>Cheers,</p><p>Nello</p>
Has a new compressor on it.(the car)
sir, what would be the possible cause of unwanted odor entering the car through the A/C?
The smell is coming from the evaporator. The smell is a problem on older cars, that is why newer vehicles come with a cabin air filter to prevent dust and other things from getting into the evaporator and decomposing. <br> <br>They do make products to try and clean it without disassembling the dash. Sometimes they work and most of the time they don't. <br> <br>The bast way to cure the smell is to take dash apart and clean the evaporator with bleach or some type of recommended coil cleaner. <br> <br> <br>
Using propane and other flammable refrigerants is illegal in many states and really upsets those who do it professionally, as it contaminates very expensive equipment. Also evaporator leaks can be found with an electronic leak detector at the evaporator drain or by taking out the blower motor resistor and checking through there (dye often will show up there as well). <br>Recovering hoses is also required by law if the hose is longer than 1foot.<br>Also the EPA license to buy R12 is really easy, its an open book test and can be taken through ASE.
A good friend of mine worked for a refrigeration company and after talking with the engineeers replaced the gas in his AC unit with Propane. worked pretty well apparently and real cheap.<br>
here is how mechanics find leaks: 1 fill system with nitrogen 2 spray foam all over engine(they did that) if it bubbles you got a leak 3close the leak 4 retrieve freon,seperate nitrogen 5 fill old freon back,add more if necessary
relaceing gas type coolent into the ansophere is a goverment offence
Letting freon out into the atmosphere intentionally is a governmental offense. But if its leaking out of the system or when you clear the gauge hose its not an offense . If the government was so concerned about freon in the atmosphere they would sell it to the do it your selfer. Freon r-12 and 22 destroy ozone Freon r-134a is a green house gas. I would not have had to fix my a/c myself, if the shop had done there job correctly and fix all the leaks instead of just one and fill the system with freon. The law states that they have to fix a leak, but when you have an old car like mines due to vibration you could have many little leaks.
Wow... Actually a pretty detailed Instructable, nice job.
About This Instructable
243,350views
106favorites
License:
More by ivanbg:How to replace a valve stem How to Repair Automotive A/C
Add instructable to:
