How to Repair Flashlight Switch (Fix Tailcap Switch)
1,193
10
6
Posted
Introduction: How to Repair Flashlight Switch (Fix Tailcap Switch)
Hello, Everyone!
in This Instructable, I will share with you How to Fix the Mechanical Switch in Flashlights (this method Should Work on Most flashlights except the Old Models like Maglite )
I will demonstrate the Repair on Skywolfeye Zoomable Torch
ok, Let's Begin :)
Step 1: Gently Pull the Rubber Cap
*The Switch in this torch is Press-fitted, if The Switch in your Torch is Screwed in Then unscrew it first, Then pull the Rubber Cap
Step 2: Use Something Thin But Not Sharp to Push the Plastic Housing Out of the Tailcap , Tap It Gently
Step 3: Pull the Switch From the Plastic Housing
Step 4: Measure the Resistance of the Switch to Make Sure That the Problem in the Flashlight Is Caused by the Switch Not From the Pill
Step 5: Use a Thin Object to Pry Open the Switch Through the Holes on the Sides
if your Switch Does not Have Holes on the Sides Then use Something very thin
like a flat head screwdriver to wedge between the Side Crack of the switch (But Be careful not to cut yourself)
Step 6: After Opening the Switch , Clean Its 3 Pins Very Well
Use a metal File or Sand Paper to Remove any Rust from The Surface of the Conductors.
but don't file it too much, Just Scratch The Surface.
Step 7: After Cleaning the Pins, Reassemble the Switch
Step 8: Measure the Resistance of the Switch
Before the Repair The Resistance was 13 ohm, After the Repair, it Became in the Range of 0.01-0.1 OHM , Which means it became as good as new.
Step 9: Put the Repaired Switch Back in the Plastic Housing
Step 10: Insert the Rubber Cap
Step 11: Insert the Plastic Housing , Then Tap It Lightly to Secure It in the Tailcap
Step 12: Connect the Tailcap to the Flashlight and Test It
it Should Work :)
For More Details, Watch the Eembedded Video.
I hope This instructable was helpful to you
Thank you for Reading.
Thulfiqar Ali
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
4 Comments
If you could get some solderon the cleaned contacts your repair might last a lot longer
Thanks for the tip :)
Neat, I'm glad you could fix it :)
Thank you swansong <3
