How to Repair Samsung Galaxy S5 Glass Only
Introduction: How to Repair Samsung Galaxy S5 Glass Only
In this instructable I will guide you on how to apply a brand new glass screen onto a Samsung Galaxy S5 cell phone. Now I expect you were able to separate your cracked glass from your working lcd display. In order to do this you will need an lcd separator machine to be able to get the glass off the lcd. I made an instructable called "How to Replace Glass Only Screen on your iPhone 5s", follow that in order to separate the glass away it is the same processes. You cannot do the repair without the machine. A heat gun will not work! Check out lcd separator machine reviews for more info on the machine itself.
In order to adhere the new screen on the lcd, we use uv glue and a uv light.
Lets begin.
Step 1: Put It in the Mold
You will need to use a mold for this repair. The mold helps the new screen lay perfect on the lcd. You must have one. Buy them here.
Step 2: Double Check
Make sure the lcd is free of any dust and figure prints. I assume you already have removed the old loca glue.
Step 3: Apply the Glue
You will need to use loca glue. This is a special glue that dried only under uv light. No other glue will work!
Buy it here.
Apply the glue in "Y" form. So you will have two "Y" connecting to each other like in the picture. This is so air bubbles do not get in and the glue spreads evenly.
Step 4: Replacement Screen
Take your replacement screen and put it down on one side, while slowly lowering it on the other with a paper clip. If you do it too fast, you will get air bubbles.
Buy replacement screen here.
Step 5: UV Light
Once the new screen in on the lcd, make sure there are not bubbles. If there are bubbles you will want to squeeze them out gently.
You can either use a uv light, but I prefer a nail dryer. Works the same. Put it in for 5 minutes.
Step 6: Finished
Finally wipe any excess glue that didn't dry around the screen. Test out the screen to make sure the touch is recognized and the screen has no blemishes. You can now put it back onto your phone.
If you are going to be doing this repair, please help me out and purchase your supplies through my Amazon Affiliate links it would really help me out! Thanks!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    all you do is just advertise products and parts but no detail about ribbon cables disassembling, cautions and other thing .i hope you ll make alots of money ...i am not going to hit your dam affiliate link too
    Uhhh... i think, it's Galaxy S3.
    A heat gun will work.
    I have done 100+ with just a heat gun on a smd station .
