loading
Step 2: Remove Sticker and Split Ring
First, remove the sticker on the fan. That will expose the shaft and the split ring that holds the fan in place. Use the pick to gently pry the split ring off the shaft and remove the fan. Set the split ring aside for reassembly later. If possible, leave the o-ring in place. Otherwise, put it on the fan shaft.
<p>What if there is nothing exposed other than the fan housing when you remove the sticker? Then you need to head on over to my new article. </p><p>http://www.instructables.com/id/Noisy-Computer-Fan-Repair/</p>
What to do if there is no split ring?
There should be some kind of clip holding the axle in place.
Great tutorial. Very helpful. My GPU Cooler works like new. Thanks
would sewing maching lube work too?
If you can get in there and wipe the crud out the bearing, it works that much better.<br />
&nbsp;Awesome to see someone else that figured out how to open computer fans right up!
great instructable! my servers cpu fan sounds like theres a gun fight goin on inside my pc lol
That would be awesome! :D<br />
or it could be all the dust mites having a nuclear war in there :O
you should also blast the "fins" with compressed air to get the dust off
For that I useubbing alcohol.
thanks for this. i had a slow fan on a drive enclosure and the tip to take off the sticker was the one that set me up. thanks a lot.
You can also use sewing machine oil on a Q-tip.But use no more than one drop for each part.Shaft gets one drop with Q-tip and bearing gets one drop straight from the bottle.
Use grease instead of oil and it'll last longer
Actually for computer fans oil would work better. In all reality, most computer fans will never really need any sort of lubrication. I've re-oiled the fans on my computer that runs 24/7 only once in the past 3 years
I've used oil and oil and oil and then switched to grease and never had to re-do them.
wow, how old and how often is your computer on?
My computer started with a 486 and its been upgraded a part here and a part there for 15 or so years. I think the floppy is still original. :P
correct: how to repair most GPU fans... any idea on normal,cpu or power supply fans?they sound like 7 years old vacuums(not pc's)...
The process should be nearly identical for any fan in your PC. Just remove the fan, remove the sticker, remove the split ring, lubricate, and reassemble.
thanks for reply
About This Instructable
107,966views
24favorites
License:
More by damonkohler:How to Repair a Computer Fan OLPC Telepresence
Add instructable to:
