Disclaimer!
Don't blame me if you break your broken speaker cones lol.
This wont properly work on metal or plastic cones.
This fix will likely not make your speakers sound better than they did before they cracked. It should however sound better than they did when they were cracked.
Remove these ads by
Signing UpStep 1Required Tools
Elmer's glue, gorilla glue (this stuff also works great for fixing cracks in speaker dust covers), or another type of semi flexible wood glue
A regular coffee filter.
A paint brush. I recommend a semi stiff bristled brush as it helps to rub the glue into the speaker cone
Scissors
A plate
and last but not least a broken speaker...Duh
At step 3 photo 5 you say "There is no fix for this kind of crack...": I fixed a badly broken speaker's rubber suspension, using silicone sealant and an old light fabric strip. It does not look pretty, but it is operational.
Thanks for you support :)
Just foor for thought, but have you tried Plasti-Dip for the outside rubber cracked part of the speaker ???
i have two 8-inch tornado's and they both have had extensive repair work done with clear plastidip (can also be thinned)
