loading
Step 3: Filling in and patching the crack.
Start by filling in the crack with glue and letting it dry. Depending on how badly cracked your cone is it might take several applications. Remember to get both sides top and bottom of the cone filled with glue. Next take a piece of the coffee filter and cut it to size so that it covers about a quarter inch to a half inch on every side of the crack. Try and tear the coffee paper whenever possible instead of cutting it. This helps the fiber bond to the cone better and prevent the edges of the patch from peeling up over time. now use your paint brush and glue the patch on. Apply a relatively liberal amount of glue to the top and bottom of the patch patch as well as the cone it's self. Once your done it may be a good idea to go back around and put some more glue around the edges of the patch to keep it stuck down. You can now let the glue dry. Genially you sould only need one layer of the coffee filter patch but in high wattage applications like large subs I recommend adding a second layer of the patch for safety.
<p>So I've been looking at other information on how to do this, and a lot of people don't bother watering down the glue, they just slap it on and get good results, as well as applying a patch to both sides, can you see any downside to any of this? I'm a little worried because I'm fixing a hole in some PA speakers I bought, and they're expensive to replace. </p>
<p>Thank you so much for this. One of our Mission speakers started buzzing and vibrating, especially on bass lines. It ruined all our music and my husband was looking at getting new speakers. Didn't really want to do that. Then he discovered that the speaker cone was loose half way round the edge. He looked online for help and found your instructable ( I did say to him where else would you get that kind of help :-) ). He used your white glue method and the speaker is good as new. Thank you - we are really happy to have our music back with no buzzing and vibrating!</p>
<p>Paint can be brittle. Try a water based stain instead. Sinks right in.</p>
Don't Elmers (AKA &quot;school glue&quot; or &quot;white&quot; glue) and Gorilla glue get pretty brittle when they dry? You think a more flexible when dry glue may be better suited for all the vibration it will encounter?
Well elmers seems to work pretty well, I wouldn't recommend something like epoxy because that will crack. I also wouldn't recommend something super flexible like silicone sealant as it will damage the sound quality. Basically any semi flexible wood glue works well.
Ah...I see. Good! Just wondering.
hi &amp; geat instructable - thanks ! <br> <br>Just foor for thought, but have you tried Plasti-Dip for the outside rubber cracked part of the speaker ??? <br> <br>i have two 8-inch tornado's and they both have had extensive repair work done with clear plastidip (can also be thinned)
there is copydex or other latex glues
hi i have a 12 in subwoofer with a crack less then 1 inch can any one help
Good work!<br><br>At step 3 photo 5 you say &quot;There is no fix for this kind of crack...&quot;: I fixed a badly broken speaker's rubber suspension, using silicone sealant and an old light fabric strip. It does not look pretty, but it is operational.<br> <br>
Cool! I figured that someone would probably call me on that :). I've tried it myself too. Yes it works but I don't think they sound the same when your done. Maybe I just did it wrong, I don't know.<br>Thanks for you support :)
Obviously, the solution is to change the cone, done by somebody that knows the trade. My work was over a relatively cheap speaker, without ambitions.
About This Instructable
108,674views
28favorites
License:
More by coolpizzadude:How to Repair a Cracked Speaker Cone. How to clean a Roomba How to repair capacitors on computer motherboards and other electronic devices.
Add instructable to:
