Step 4Removing a Flywheel
iImage Information
Removing a flywheel can be a aggravating process if you do not know the tricks. The nut which holds the flywheel is on very tightly, and can only be removed by blocking the rotation of the crank shaft with a wrench holding the nut on the blade or by blocking the rotation of the blade. Do not try to hold the flywheel by sticking a crowbar in the teeth, or they might break off. Once you have remove the nut which holds the flywheel in place you will need to gently pry off the flywheel with a crowbar. Keep rotating the flywheel until it can be lifted off easily. Now put the flywheel key somewhere safe. When you want to put the flywheel back on make sure that the key is in the right direction. It is usually marked in some way.
It's a pane in the but to remove the flywheel on older models you have to drill and tap the holes and then pull the flywheel with a puller
