How to Repair a Rusty Wheelbarrow
17,023
30
10
Published
Introduction: How to Repair a Rusty Wheelbarrow
My school garden class had a rusty wheelbarrow out in the backyard that needed to either be thrown away or be repaired.
The rust was so bad that stuff would fall through. It was both inconvenient and dangerous to use.
We came up with an idea to fix it without having to go out to the store and purchase a new one.
In this Instructable I will show you how you can repair a rusty wheelbarrow.
Hope you enjoy it!
Step 1: Materials Needed
Here's the tools you need to have
Safety Glasses/Gloves
Pop Rivets
Pop Rivet Tool
Tin Snips
Pliers
Electric drill
3/16 drill bit
Aluminium Sheet Metal (aluminum flashing from a hardware store will work)
Marker
All these items are easy to find at any hardware store.
Step 2: Make a Pattern
First ,You find old cardboard and cut the right pattern for your wheelbarrow.
You cut the right pieces to make your pattern fit. Make sure you make the pieces much bigger than the rust holes so that you can attach it to metal that is still solid. The area near the hole will be to badly rusted for the rivets to hold.
You will use the cardboard cut out later to trace it on to the sheet metal.
Step 3:
Trace the pattern that you cut out onto the sheet metal.
Once you trace it use the shears or tin snips to cut it out.
Step 4: Rivet Sheet Metal With Pop Rivets
Place sheet metal where damage is done. Using a electric drill you drill holes through wheelbarrow and sheet metal  using 3/16 drill bit.
Now attach the sheet metal with the 3/16 pop rivet. You can  use the back up washers on the back side of the rivet to make sure the rivet does not pull through.
Step 5:
Now repeat the same process by riveting and making sure the other pieces of sheet metal are attached to the wheel barrow and cover the holes.
Step 6: Ready to Use!
Now that all sheet metal is in place covering up damage,  it is ready to be used again.
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
  • Make it Move Contest
10 Comments
Good job, good Instructable.
I repaired my rusty wheelbarrow a couple of weeks ago. But yours - you should get some kind of award!
Your repair should be fine.
Not expensive. I keep a roll of the .010" aluminum flashing in my shop for just such repairs.
You might want to put some caulk under the flashing if you want to haul liquids in your wheelbarrow.
a good sanding and a coat of rustoleum to before adding the flashing may prevent any further rusting and will help prolong the repair.
A wooden box is another way to go. Fixing things with what you have is worth it in my opinion. If you have sheet metal use it. If you have wood use that. I think the sheet metal fix will hold up well and was a pretty quick fix. Besides working with sheet metal and pop rivets is fun.
Not worth the effort. Remove the tub and replace it with a wooden box. I am saving my ratty barrow for better Instructables.
