How to Replace Old Computer Batteries
2,844
41
6
Posted
Introduction: How to Replace Old Computer Batteries
Tried of replacing your batteries every 2 years for you laptop?
Now you can change your batteries in your laptop so you will not have to spend $100 on a new battery
Step 1: Start
Disconnect the battery from your laptop. There will be 2 tabs on each side of the battery, just slide them to the side and pull it out.
Step 2: Take Apart
Pry the battery apart. You may also need some patience and a sharp flathead screwdriver or a butter/putty knife.
Step 3: Tracing Wires
You will see 6-8 cells connected to a circuit board. That is the battery controller. Look near the connector to find the board, and trace the wires. Carefully examine every cells by a multimeter to ensure the cells are fully discharged.
Make a note of where the wires connect to. This is important because if you forget to place the wires in the correct place the battery may destroy your computer.
Step 4: Electrical
Use a soldering iron/electric welding tool to separate cells from the wires. Then take them out of the case
Then solder/weld the new cells together. Remember to refer back to the note you made in Step 3.
Put the new cells into the case. Solder/weld back the wires and cells.
In the end put both rows of cells back together. Let it rest for about 48 hours.
Step 5: Finished
Now you are DONE!! Insert your battery and start charging. Turn it on, and you're ready to turn on your computer!!!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
6 Comments
In two cases I found that whereas the cells themselves were still good but the controller was kaput. From what I've read, some manufacturers (shame on you Sony, Dell) actually have the controllers blow an internal "fuse" after N battery cycles. Your mileage may vary.
It's entirely possible that they know that the batteries no longer charge well and/or are subject to catastrophic failure or heating beyond a certain point and that this "fuse" you refer to is actually a safety feature, not a way to make you buy a new battery solely for their profit. -- Just because the cells still don't measure as 0 volts or some cuh doesn't necessarily mean that they're still good.(http://www.mpoweruk.com/lithium_failures.htm)
Hi there,
One thing that confused me a little, why do you say: Let it rest for about 48 hours?
Cheers,
R
Oh, for my battery I had to glue it back together so That is why you should wait 2 days for the glue to dry. I always take my projects slowly since I want good results.
Any tips on what kind of cells should be used? I bought a replacement unit on-line and it was pretty poor, maybe had poor cells in it..?
If that replacement unit can be returned you will want to contact them as soon as possible and see if you can replace it again. There are many things that could have gone wrong. It could be the connections between the cells or, like you said, bad cells.
If you want to replace the cells then you will have to find the battery cells that are the same as the ones that the company recommend.
But once you open the battery you will no longer be able to send it back to the computer company to have it replaced!!
