loading
Step 5: Remove Brake Pad Holder
I don't know if this is it's official name but that's what i'm calling it. These bolts were secured by the mechanics using "lock tight" so they are really difficult to get undone.  We used a big ass pipe wrench a large ratchet  a medium wrench  a hammer a big metal lever and the small piece of abs pipe to undo these bolts.I'm sorry that the pictures aren't vary good but it is a small space with a big person and tools in the way.  Anyway if your's aren't secured with "lock tight" it's probably allot easier.
<p>Pretty comprehensive and will be utilizing it this next weekend. Nice Job!!!</p>
thanks
It's also a good idea to bleed the brake system after doing a brake job to get all the air out of the system. And make sure to pump up the brakes and make sure the pedal is firm before even turning the vehicle on let alone putting it in gear.
Thanks again, we didn't bleed the system and its working fine. It is a good idea to pump the brakes first.
When depressing the caliper piston it's a good idea to open the bleeder screw as forcing fluid back through the system can damage the butterfly valves in the ABS unit.
Thanks, I didn't know that.
The bolts on the tire need to be loosened before you jack up the car.
Thank you forgot to write that up, it's in the ible now.
The metal pipe we used was about 5 feet but it is used as a lever, I think a foot or so should do, make sure it fits over the handle of your wrench. Or take some padding and then hit the wrench with a hammer. It shouldn't be too difficult unless lock tight was used on the bolts (like ours). The clearance for the wrench was probably 3 inches, but our socket was about 2 inches long. Thanks for commenting its nice to know that people actually use what I write up -Zaphod
About This Instructable
62,161views
12favorites
License:
Bio: Second year engineering student studying at the Beautiful Okanagan campus of The University of British Columbia. I like to tinker with electronics and meddeling with ... More »
More by Zaphod Beetlebrox:Ruby's Gingersnaps How to Make your Own Popcorn How to Make a Rustic Leather Shaving Kit
Add instructable to:
