How to Restore Cloudy Headlights, and Make It Last
Published
Introduction: How to Restore Cloudy Headlights, and Make It Last
In this instructable we'll show you how to make a cloudy headlight lens shine like-new again. The process is simple, takes only about 30 minutes, and the repair lasts for around 4 years.
What you'll need:
11 oz. aerosol UV headlight clearcoat
1 half-sheet of 400-grit sandpaper
1 half-sheet of 600-grit sandpaper
1 half-sheet of 1000-grit sandpaper
Masking tape and paper
Spray bottle
Time Required: 30 minutes
Step 1: Mask Repair Area
Mask off the area around your headlight.
Step 2: Sand Headlight Lens
Wet-sand the headlight lens with 400-grit sandpaper, then with 600-grit, and finally with 1000-grit.
Once you are done, wipe it down with a lint-free cloth.
Step 3: Clearcoat Headlight Lens
Apply multiple, light coats of the UV clearcoat from a distance of around 10 inches.
Keep applying layers until the lens is clear.
Step 4: Cleanup
Wait about 10-15 minutes before removing the masking tape and paper.
You are now good to go, and the repair lasts about four years.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    4 Comments
    I disagree with not benefitting past 1000 grit. this is essentially the same thing plastic modellers do to their cars, for instance. I think the best reason not to go past 1000 grit is simply that you need a "tooth" for the sealer to catch on. if you're not worried about the sealer, go to a higher grit.
    Can you take it further with the sanding and after 1,000 grit use a 2,000 grit?
    You could, but there would be no benefit.
    stateit: It may be marketing, but if the product works, I'm interested. And it does give instructions on how to carry out the project using the advertised product. I wouldn't call it spam unless it was advertising something unrelated to making/DIY. But that's just my opinion.
