Introduction: How to Restore Tail Lights
Picture of How to Restore Tail Lights
Video tutorial on how to polish tail lights or parking lights using the wet sanding and polishing method. This will allow for removal of any fading or light scratching. Scratches that are deeper cannot be removal, but will be lightened up in most situations. Normally tail light fading isn't as severe as headlight fading as it doesn't deal with road debris flying up or bugs. The length of this procedure will normally last about a year, but that will depend on your vehicle's usage or climate. With ever vehicle wax application, it's always good to apply coats of wax to the light as this will prevent them from fading, keep them shinny, or have a protective layer from polishing.
Tools/Supplies Needed:
  • 1500 grit wet/dry sandpaper
  • 2000 grit wet/dry sandpaper
  • polishing compound
  • wax -microfiber cloth
  • microfiber applicator pad
  • soft line free cloth
  • painters tape
  • bucket of water
  • spray bottle with soapy water
Step 1:
Picture of
Start by washing the vehicle which will remove any dirt with can contaminate the restoration process. If you wish, tape off the paint using tape around the light so you don't risk the chance of damaging the surface. Pre soak the sandpaper in the bucket of water and spray down the light with soapy water. Start using 1500 grit sandpaper, removing any of the scrubbed or scratched areas, this will remove the majority of damage fast and easily, be sure to keep rinsing off the sandpaper and keeping the surface wet.
Step 2:
Picture of
Once satisfied, move onto 2000 grit around the whole light, be sure to keep rinsing off the sandpaper and keeping the surface wet. Next rinse the light off, ensure the light is mostly dry.
Step 3:
Picture of
Using polishing compound and a soft lint free cloth, apply some compound and work it into the surface. You may need to apply the polishing compound a couple times. Once satisfied, clean the light off and ensure there isn't any left over compound or wax.
Step 4:
Picture of
Apply the wax of your choice to the light using a microfiber applicator pad, work it into the surface. This will maximize the shine while also providing a protective layer against the exterior elements. Then remove and buff using the microfiber cloth.
Step 5: All Done!
Picture of All Done!
Finally once done, you should be left with something such as this.
Stay up to date with my latest tutorials, don't forget to FOLLOW my profile and be sure to check out my YOUTUBE page as well for all your DIY needs.
About This Instructable
649views
7favorites
License:
Bio: Car enthusiast YouTuber creating helpful tutorial videos on both repairs and customizations. Be sure to hit that SUBSCRIBE or FOLLOW button!
More by 4DIYers:How to Upgrade Your Vehicle's Exterior Incandescent Bulb to LEDTop 10 Money Saving Auto Repair Tips5 Ways How to Remove a Stuck Brake Drum
Add instructable to:
