3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Rig an Easy Booby Trap
I sometimes have problems with people in my family (mainly my sister) coming into my room uninvited and stealing things like movies and such. So I rigged up a simple but very effective booby trap based on a trap called the Tiger Trap (a type of dead fall) that was used by the Viet Cong in the Vietnam War. This booby trap is designed for doorways but can be adapted to just about anything. Please do not leave any rude comments, criticism is okay and questions are accepted and replied to as soon as I can.
Step 1Materials
Materials
1) Fishing Wire
2) One Plastic Tube or Container
3) One Empty Scotch Tape Spool
4) Copy Paper
19 comments
Feb 16, 2012. 6:41 AMfun1 says:
awsome it works so well.you could also put fun snaps in it so the people get a little fright,insted of using paper you could also use the bendy parts of the straws that way it will not chafe against the paper or rope. awsome moddel works so well :-):-):-)
Jan 10, 2012. 5:41 PMkestoico says:
empty toilet paper rolls work well too. so does the tubing from a hanger.
nice tiger trap....simple and effective.
Sep 11, 2011. 11:20 PMrmacon says:
I found that if you want a more permanent trap that can take weight instead of little paper tubes, for the bottom cylinder replace it with a staple that is partially inserted into the wall, remove the opposite end of the staple where the wire is resting on, bend it almost perpendicular to the wall and fold it in. And for the top one, insert a staple 2/3rds of the way into the wall. You can also staple the beginning of the trap, (The tripwire itself) to the wall as well, the triggering mechanism is the wire setting off the first bent staple, allowing the object to fall onto the target and for the trap to be reset too rather easiely instead of retaping and stuff.
The only problem is that it will not hit everyone, it depends on the length of fishing wire. If you are attempting to hit taller people, use less wire, or shorter people, use more.
Sep 11, 2011. 11:21 PMrmacon says:
If you tape the spol out far enough, the extra tape a couple inches ahead of the spool is not neccessary, it's only another thing to go wrong as well.
Nov 27, 2010. 3:40 PMHitman227 says:
I like it ill try this with my sister.
Sep 12, 2009. 3:09 PMzipzapper859 says:
how does it drop it
Apr 6, 2010. 3:32 PMKevin12345 says:
so the point where the end of the tripwire (the one opposite the containor) is attached can slip out?
Jan 16, 2010. 11:34 AMstriker187 says:
clever can't wait to try it
but it would be nice to suggest some possible substitutions for the cylinder
Mar 18, 2010. 10:37 PMpieman12 says:
cut up pen tubes would probably work
Sep 16, 2009. 8:18 PMthing 2 says:
you should post a video of someone tripping it!
Sep 11, 2009. 6:12 AMzexuan says:
I have actually tried this before. Gave up halfway considering I was still a little kid then. What do you actually put inside the container? Can it hold up water?
Sep 13, 2009. 4:56 AMzexuan says:
as in i made something similar without before this guide was published
Sep 2, 2009. 6:48 AMiloveairsoftstuff says:
try redoing the pics with regular string to make it more visable. nice though.
Sep 1, 2009. 6:08 PMIce Ghost says:
Hey nice tiger trap!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Miscellaneous
