How to Rotate Your Car's Tires
 by Irresponsible Robot
Tire rotation is an important part of ensuring your vehicle is performing as well as it ought to, and it isn't terribly difficult. The entire process doesn't take more than an hour, and the tools you need most likely came with your car!
Step 1: Things You Ought to Know
Why should I rotate my car's tires?
Rotating your tires regularly (yearly) ensures that they will wear at a similar rate, ensuring that your car handles like it should. A car with uneven tire wear may handle erratically, especially in poor road conditions, and can make emergency maneuvers unnecessarily dangerous.
Why shouldn't I rotate my car's tires?
In some cases, tire rotation is unnecessary or even inadvisable. If your tires are equally worn front and back, you probably don't need to bother. Also, if your car uses different-sized tires in the front and rear (common in high-end rear-wheel drive vehicles), tire rotation can drastically and negatively impact your car's handling.
Is there a pattern I should follow?
Yes. The pattern in which you rotate your tires is entirely dependent on which wheels are driven on your car. For a front-wheel-drive car, the front tires should move straight back, with the rears moving diagonally across the car. Rear-wheel drive is just the opposite. For 4-wheel and all-wheel drive vehicles, all four tires should move diagonally across the car. This ensures that tire wear is as consistent as possible, even if you tend to turn one direction more than the other.
The car used in the illustrations is front-wheel-drive.
The_Tom says: Feb 13, 2013. 11:06 AM
Why is it different for fwd and rwd? i was always taught that you could do either one of those but never switch between the two on the same vehicle(well not while you are using the same set of tires)
Wyattr55123 in reply to The_TomMay 20, 2013. 11:13 PM
You can also use the front to back method, with wheels staying on the same side of vehicle, but changing position, or the full x with all wheels moving diagonal. The modified x is preferred because the wheels go to every position on the vehicle
Wyattr55123 in reply to The_TomMay 20, 2013. 11:10 PM
It is different due to the use of the modified x pattern. Drive wheel stay on the same side and move forward or backwards to the other location, and free wheels move diagonal
The_Tom in reply to Wyattr55123May 21, 2013. 8:45 PM
yea but why?
randofo says: Oct 20, 2010. 10:35 AM
This is a great Instructable, but you need to add a main image of the final project to the intro step. Please do that and leave me a message when you have so that we can publish your work.
Thanks!
Irresponsible Robot (author) in reply to randofoOct 20, 2010. 11:18 AM
There we go, that should do it.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
