How to Rubber Dip Handles on Tools
1,727
40
Posted
Introduction: How to Rubber Dip Handles on Tools
Video tutorial on how to apply a rubber coated handle to tools. The product I am using is a dip rubber coating made by Plasti Dip and is available in a few different colors. You can be limited on the length of the handles as the can isn’t incredibly deep. This is a great way to protect your tools, give them a personalized look, provide some form of insulation, and increase the grip. Share photos of your newly coated tools!
Tools/Supplies Needed:
  • duff knife
  • wax and grease remover
  • pliers or whatever tools you’d like to apply the rubber coating to
  • heat gun
  • stiff wire
  • paper, cardboard, or pan
  • rubber dip coating
Step 1: Remove Existing Rubber Coating
Here I have an older set of needle nose pliers which I will be replacing the rubber coating on and as you can see, the existing rubber coating is in rough shape. Remove the existing rubber coating, sometimes you can slide these off, other times use a dull knife to score the rubber handle and then peal it off. The dull knife will reduce the risk of scratching the coating underneath which helps protect the pliers against rust, then peal the rubber off.
Step 2: Clean
Clean up the handles using some form of a wax and grease remover which doesn’t leave a coating behind. This will remove any contaminants which can cause adhesion problems or prevent sealing which will allow moisture in, eventually causing rust. If your handles are rusty, this rust must be removed, otherwise it will eventually worsen under the coating. After the rust has been remove, clean up again with a wax and grease remover and apply a light coat of primer just to the handles, where the coating will cover that up so it’s hidden.
Step 3: Create a Hanger
The pliers will need to be hung up, so have something ready before we start dipping. Here I’m using a heavier wire wrapped around the tip which won’t be in contact with the coating.
Step 4: Remove Moisture
Use a heat gun on the handles to dry up any moisture if any which can be trapped underneath and cause corrosion in the future.
Step 5: Dipping
Depending on the width of the pliers, you maybe able to coat both at the same time or only each individually. Mix the coating accordingly, be sure to read the instructions on the side of the can depending on what coating you are working with. Submerge the handles and then extract them slowly, it’s important to apply the coating on a day with lower humidity as it will affect dry time. Also do not work in windy conditions as this will cause problems as well. It’s good practice to hang them up above paper, cardboard, or a pan to catch drips and for easy clean up. Allow them to dry for about 30min, apply a second layer and finally a third layer. You will want to apply at least three layers to provide a stronger durability.
Step 6: All Done
Allow them to harden and you’re done!
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
