Step 3Joining Box and Cable
Place the cable in the holes of the box, then pull out the four wires that you cut earlier. Then screw in the Phono jacks, in the 3 holes you drilled earlier. Screw on the nut that should have come with the phono jack, and make sure you put the little loop in between the nut and box on the thread. Next solder the Blue, Brown-White, and Brown wires to the positive posts on the phono plugs(see pics below). Then solder the Blue-White wire, to the little loop on the thread of the designated Video plug. Now solder patch wires to the Right and Left grounding rings from the Video grounding ring.
For those with Ethernet crimpers and jacks
To be frank the only diffrence is that you run your cable through the box, and pull out he 4 wires mentioned above (blue-white, Blue, Brown-White, Brown) before you solder them, but make sure you leave the other four running to the end of the cable.
My illustration is wrong in the fact that the Brown, Brown-White, Blue, and Blue-White wires are not crimped into the jack.
comments
Add Comment
Add Comment
