- I actually created this instructable over a year ago, but I never got around to posting it. Everything is still applicable though!
Remove these ads by
Signing UpStep 1First and Foremost
*How close do i live to work?
OR
*Is my car a gas guzzler?
The reason this is important is because many people believe that they need to purchase hybrids just so that they pollute less and save gas money; however, that is not always the case. For example, if I own a hummer and get 10 mpg and you own a hybrid and get 45 mpg, yet you live 5 times farther from your work than i do, then you're carbon footprint is the same, if not worse. So, yes, buying a nice new hybrid is important, but also consider either moving closer to work or possibly getting transferred to a closer satellite office if applicable.
- details a finished project with instruction (not just links to instructions)
- has clear images that you took of your project (web-found clip-art is not acceptable)
- uses proper spelling and grammar
- contains appropriate cautions or safety considerations
- does not violate someone else's copyright
- does not violate the Instructables terms of service
- is typically written about something you are very passionate about and want to share.
If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums. Look here for tips on writing a great Instructable.
http://www.instructables.com/id/ELHMNOA69REUF10WM7/
So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
1. Using lowest recommended for your car viscosity synthetic motor oil helps engine run easier - saves $$.
2. IF you don't travel far: slightly OVER inflating your tires also helps save fuel $$.
