3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Save a Water Damaged Verizon EnV Phone.
  • last photo ←
I would like to open with a simple greeting, I am not a technician for a phone company, I actually never took one apart until now. There is nothing that can be put together, that cant be taken apart. This said, nothing is impossible to take apart, just take your time. This guide is how to take apart an EnV Phone if it is water damaged. When I say water damaged I mean DAMAGED! My phone was run through a washing machine and every screen and the camera had water in them. I did this method and it worked, mentioned it to a friend at school, he did it and couldn't believe it. Unfortunately many carriers including Verizon won't return a water damaged phone, or the old case of not having insurance. This guide will help you in your process of saving your phone for cheaper than a new $400 unit. This also applies to other phones, you just need to apply the simple basics of taking phones apart.
A few WARNINGS, make sure your phone isn't covered under warranty, I repeat make sure your phone isn't covered under warranty, this will ultimately Void your warranty. Secondly, the parts on this phone are really ticklish, they don't need much force to break. Screws are coated with blue loc-tite, so they round off, little ribbon cables break EASILY. So if at all you can just take your time and do it right you won't have a headache, or misplaced part. Or worst case a phone with a screw that has to be drilled out, this is bad news bears.
What you need:
1. Jewlers Screwdrivers ( + for the tiny screws holding together the chassis and other parts; - for wedging into joints and popping out screw covers.
2. Alcohol Preferably 91% (Alcohol will evaporate water off of the circuit boards, and will also clean them)
3. Q-Tips (Cotton preferably)
4. Paper towel
5. Blow Dryer.
6. Magnet Tray (bowl or coffee mug works too)
7. Pin or spudger tool.
If you are using the Alcohol, please use it on a swab, you don't want to put too much on the circuits.
I am not responsible for you phone BTW.
Step 1Take off plastic plugs.
Remove battery.
Remove all the plastic plugs from the back of the unit. This is done by putting a pin under the lip and then pushing a flathead jewlers screwdriver into it and wedge it out, they should come out pretty easily.
Proceed to carefully remove the screws.
6 comments
Jul 26, 2010. 12:38 PMNotAGenius says:
decent tutorial, for some reason after i did all this, my mini lcd above my numpad blinks on an off, and my main lcd seems to fade from bright to barely visible; anyone know why this is?
Apr 19, 2009. 10:17 AMjohn n0ob says:
the lower plug things are actually below on the outer side of the speakers
Sep 22, 2008. 8:58 PMalex-sharetskiy says:
time to find a water damaged phone on ebay!
Sep 22, 2008. 9:02 PMac1D says:
yep, they are rare, but go for a few buck!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Bisquick
