How to Save a Wet Cell Phone
Step 5Unverified Methods
The following are methods that I have not verified myself. Next time my phone gets wet, I'll try some out!
1: The oven
It is said that placing the phone in the oven for a few hours at about 125 F. will solve the problem. This method sounds likely, but I would recommend taking it out now and then to test it and let it cool! And don't forget to remove the battery, cover, and SIM card!
UPDATE:
User Carolradtech has tried this method, and said the following.
I successfully baked my wet cell phone on 125 for 40 minutes and the phone is now fixed. ...the unverified baking method is now verified.
2: Rice
It has also been reported that placing the phone in a bowl of rice while putting it in the sun allows the moisture to absorb faster. As the water evaporates into steam, the dry rice can absorb it rather than have it re-condense elsewhere inside the phone.
3: Silica!
This one is similar to the rice method, it just utilizes a better drying agent. Ya know those little packets that come in jerky, new shoes, purses, backpacks, whatever, that say "DO NOT EAT" all over them? The contain little balls of a chemical called "silica." Place these in a bag with the phone, and toss it in the sun! This is potentially the best method I have heard of. It is also of note that craft shops sell silica as a flower drying agent.
4: Give it booze!
Well not exactly.. Isopropyl alcohol (rubbing alcohol) is non-conductive. It is said that if you get some, put it in a cup or a bucket, and swirl the phone around in there, it will rinse out the water and likely even clean some dust deposits! This will prevent any further "bridging" of connections as it is non-conductive, and alcohol evaporates super fast.
A few words of caution: I would try this only with the bottom half of your phone if you have a flip-phone, as I am not sure how the screen will react. Also, I wouldn't attempt it with anything less than 91% isopropyl.
Last but not least..
5: Open it up and air dry!
This is the best method hands down, but it will sacrifice any sort of warranty you had. I do NOT recommend this method unless you are entirely comfortable with it.
1 comment
Nov 23, 2008. 9:02 AMelifad says:
Rice does absorb moisture, that’s why a little is put with the salt in the salt shaker to prevent it from clumping.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:XHorntail
