3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Secure Your USB Drive
Everyone has files they don't want others seeing. Maybe they are financial documents, school work, or other "questionable" files. Whatever they are, you want a way to secure them. Putting a password on your PC will do you no good, and it would not be portable. Buying a USB drive makes data portable, put usually not secure. For truly secure data, you need an encrypted USB drive.
I will show you how to make a super, unhackable USB drive. It will be of no use to anyone but you, and even if someone had access to government grade hacking software, they would not be able to access the data.
I am NOT responsible for whatever you put on the drive, or whatever damage you do with said data or the drive.
Step 1The Tools
The Tools
First and foremost, you need two things:
1) A USB drive
2) TrueCrypt
The USB drive can be obtained at any store that sells material items. You should probably get a 1GB or bigger, because 1GB only costs about $10. I am using a 4GB that I have had for 2 years (same as the one in the picture below, just half the memory).
TrueCrypt is an open-source (free for your not-so-computer-knowledgeable-person) software. It uses government grade encryption (256-bit) and better, so you can be sure your data is safe. You can download it at http://www.truecrypt.org/. After installing it, you will need to restart your computer.
63 comments
1-40 of 63next »
Aug 9, 2011. 2:24 AMshadow wave rider says:
what is the gutmann method? please tell me
Aug 18, 2011. 2:26 AMshadow wave rider says:
will it deleat everything even if im entering my really really long password and i tap a wrong key.
Jun 17, 2011. 8:22 PMJamez Britton says:
TrueCrypt is good for encrypting documents and securing them but it is hackable.
I've done it before because I accidently forgot my password for it.
Jun 25, 2011. 12:38 AMJamez Britton says:
i downloaded a government-grade password variable hacker
Oct 6, 2009. 2:01 AMIAMAFISH says:
Thanks for the instructable it has been very useful. What if your a paranoid terrorist government agent instead of just one of them?
Aug 10, 2010. 2:13 AMmichaelb958 says:
I'm rolling around on the floor laughing at the above right now...
Jul 20, 2010. 1:45 AMjvpernis says:
can you make an usb which encrypts all files on the hard drive (and really secret files stored on the usb) until the usb is plugged in? and if u pull out the usb that all files will encrypt automaticly again? that'd be awesome because it is kinda like a key to your computer. very useful when u have a laptop. nice instructable by the way!
Jun 30, 2010. 9:59 AMArduMir says:
A good starter tutorial, but Step 4 in your article is not always correct. I'm purely writing this to be informative, not to insult you. Flash drives use flash memory to store data, which tends to wear down after a prolonged usage. To prevent it from wearing down as quick, a technique called 'wear leveling' was implemented. Instead of a physical sector of the drive being overwritten like a normal disk, new data gets written to unused sectors of memory, while the 'overwritten data' just becomes free to use. Basically, there's two problems you'll have. The first is you won't actually be overwriting the old data, it will just write off to unused sectors to prevent wearing. Second is you're using the Gutmann method to make 35 passes across unused sectors that may never overwrite the old data, also causing wearing to your flash drive.
Jun 20, 2010. 3:00 PMlockpick says:
Hi I'm on a Mac and when I attempt to encrypt my flash drive it asks me for a pass word and when I enter a password it says incorrect. Any help?
May 18, 2010. 7:51 PMred 9er says:
Can i apply this method to say, an entire internal hard drive in a computer?
Sep 17, 2009. 9:08 PMbsoud says:
I have an external drive for work. Its encrypted and I was able to mount the drive at work. However, when I try to auto mount it at home, i put in the password, and it says "Incorrect password or no TrueCrypt volume found"...I Absolutely have the right password, its the one I used at work. Any ideas?
Apr 24, 2010. 10:14 AMmox386 says:
I have the same problem, and there seems to be nothing out there on the internet about the Truecrypt "Incorrect password or no TrueCrypt volume found" error on the automount feature of truecrypt. It's getting to be a real hassle as it used to work on this computer. You can kinda tell others are having the issue, but there are no answers out there yet, and I've been searching for a few months off and on.
May 8, 2009. 7:11 PMdirtbike985 says:
(removed by author or community request)
Apr 13, 2010. 2:17 PMSaturn V says:
WHO CARES!!!!!!!!
Apr 8, 2010. 10:18 PMivorandjuan says:
 hi i think that you have been bullied into believing everything the US government tells you hell if it is illegal then lets use it. usually a government makes something illegal if they cant make any money on it or they crack it
Mar 25, 2010. 5:22 PMM4industries says:
 BS
Aug 28, 2009. 11:23 PMBBBower says:
How would encryption of your own data as such be illegal, is that like you cant put more than 3 padlocks on a bicycle?
Dec 30, 2009. 2:03 AMwatzhisface says:
lol
Apr 8, 2010. 5:59 PMM4industries says:
 It says resource busy whenever I enter the password.
Apr 8, 2010. 5:41 PMM4industries says:
 Hi, on a mac, I see a select device button at the bottom of the screen, do I need to worry about this section?
Apr 8, 2010. 5:47 PMM4industries says:
 On second thought, never mind, my new question is it asks me my volume location and to select file.
Mar 25, 2010. 5:26 PMM4industries says:
 Can I add documents as I save them without reformatting?
Oct 29, 2009. 6:50 PMlife-is-beautiful says:
and the retartard states he is a terriost govenment agent and paranoid. well i say good luck with that. and good work on the instructable i put it on my flash and it works exept the fact that when i go to use it my computer says insert a drive into the port.
Aug 30, 2009. 4:17 PMPsychic Master says:
can the drive be mounted without the truecrypt software installed on the computer you are using?
Aug 26, 2009. 6:15 PMrada194 says:
How would we put are computer password as the truecrypt encryption is that possible
Jun 28, 2009. 8:41 PMMr. Geek says:
im having a problem, or im just really dumb, I made an encrypted file, but i can just go into windows explorer and open it up.
Jul 5, 2009. 7:56 AMfrodobot says:
This is a really cool idea. BUT, my problem is that where you put "A hidden partition gives you what is called "plausable deniability." This means that there is a hidden drive there, and someone may know it, but they cannot prove it. A hidden partition is a great place to put REALLY sensitive documents." made me immediately think that paedophiles and internet perves could use this to hide paedophilic files and images. Does anybody think the same?
May 29, 2009. 9:09 PMEl Mano says:
I just want to check before I take a shot at ruinig my new USB drive: how do you remove the encryption and return the encrypted drive to its original state? Secondly, I've hunted through the TrueCrypt user's guide, but I can't find my answer: do you have to have TrueCrypt on the computer to open the drive? I gather that the process encrypts the entire drive, leaving no space to carry around the TrueCrypt files. Rather useless if you want to use the drive on a computer at school or someplace.
1-40 of 63next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:Crazy Leprecaun
