How to Service a Sewing Machine
50,256
420
54
Published
Introduction: How to Service a Sewing Machine
About: You can also find me on iFixit.com and Twitter @pleriche. Volunteer with TheRestartProject.org and keen to share my knowledge and skills and do anything I can to encourage girls to follow STEM subjects.
Huge numbers of sewing machines have been manufactured over the years. The older vintage machines are virtually indestructible, indeed one highly skilled and experienced seamstress told me that she still uses a 1929 treadle machine as her daily workhorse. Newer machines, especially the very cheap ones, have many more plastic parts and a much shorter life. Nevertheless, the life and effectiveness of any machine can be extended with simple maintenance, and my aim here is to show you how.
For demonstration purposes in this Instructable I will use a vintage machine probably dating from the 1950's or 60's because it's easier to show the mechanism, however, all machines work in the same way. If you can get hold of such a machine, so long as it's complete, you should be able to keep it running indefinitely and certainly much longer than a modern machine.
You can find an expanded version of this Instructable, including a description of sewing machine principles and common problems and their solutions in the Sewing Machines page on the Restart Project wiki.
Many spare parts, particularly for older machines, are readily available on eBay and probably elsewhere.
Step 1: Removing Fluff and Dust
The first thing to do is to remove all dust and fluff, wherever you can find it. Between the feed dogs is a favourite place for it to collect. Remove the needle, the foot and the needle plate to facilitate cleaning. The needle plate is a plate beneath the foot with cut-outs through which the feed dogs protrude, generally secured by one or two screws. Where the dust and fluff has become matted you can pick it out with a pin or a needle, otherwise use a brush and/or a vacuum cleaner crevice tool. You can use a can of compressed air or simply blow but there is a risk you might just blow the fluff further into the mechanism. Look out for any pieces of broken needle which might have come to rest here and could jam the mechanism.
Also, check for and remove any dust, fluff or pieces of broken thread where the thread passes between the discs of the upper tension adjuster, and at any other points in the threading path of the upper thread where it might have collected. Good quality thread sheds less fluff than cheaper brands and so is advised.
Replace the foot. Check the needle before refitting it. Run it between your fingers from the shank down to the tip. Any roughness can be carefully removed with fine emery, but it is better replaced if it has seen more than 6 - 8 hours' service. Always replace a bent needle as it will cause nothing but trouble.
Step 2: Checking the Bobbin
In a vintage machine the bobbin is often accessed by sliding away a plate next to the needle plate, as shown in the first photo. In modern front loading machines a very similar mechanism is accessed from the front of the machine. In modern top loading machines the bobbin is dropped horizontally into a mechanism in front of the needle plate.
Many very old (like pre-war) machines have a completely different bobbin fitting into a bullet-shaped shuttle which is thrown through a loop in the upper thread to make each stitch.
On a vintage machine as shown, the mechanism is hinged on a wooden base and can be lowered into a horizontal position and rested on a pile of fat books for easy access to the underneath. The remaining photos were taken with it in this position.
Remove the bobbin and bobbin case and remove the bobbin from its case. Blow out any dust.
The bobbin case fits into a bobbin case holder which rotates as the machine operates. It should be easily removed, for example by releasing a pair of clips on a retaining ring.
The bobbin case holder has a sharp point known as the hook (shown in the last photo), designed to catch the upper thread so as to engage it with the lower thread and make a stitch. Run your finger over this and if it feels rough (probably due to needle strikes) then smooth off any burrs with fine emery. Take care to reassemble it correctly.
In the case of a second hand machine, make sure that all the bobbins that came with it (and any extra ones that you buy) are of the right sort. There are several types, superficially similar, and the wrong ones will cause problems if they work at all.
Step 3: Lubrication
This is easy on a vintage machine. The bottom mechanism is accessed by tipping it on its side as in the previous step, and the top mechanism can generally be accessed by removing a couple of screws retaining the top cover.
On a modern plastic machine you will generally have to remove a number of screws, and you may then have to release a series of clips holding 2 halves of the plastic case together. Probe the crack between them with a thin spatula or blunt scalpel or thin knife in order to determine where the clips are. Take care not to insert it too far or to damage the plastic. Angling the spatula so as to lift one side of the case whilst depressing the other should release a nearby clip. Insert an old credit card, plastic prying tool, guitar plectrum or anything similar in the gap so created to prevent the clip re-engaging while you probe for the next one. Stubborn refusal of the case to come apart often means there's one more screw, possibly hidden under a label or a rubber foot.
Having gained access to the top and bottom mechanisms, gently turn the hand wheel to see which bits move. Anything that moves needs oiling on its bearings, joints or sliding surfaces, except for nylon gears, wheels or cams - these are generally greased for life.
Use only sewing machine oil. Never use bicycle oil, or motor oil, or grease, or olive oil, or Vaseline, or anything else. None of these are sewing machine friendly.
Apply no more than a drop of oil to each bearing or connection. Wipe away any excess before it has a chance to drip.
In the case of a vintage machine that has been out of use for a long time, the mechanism may be very stiff or have seized up completely. Oil it thoroughly (but wiping away any excess) and leave it for a while for the oil to penetrate. Repeat as necessary until it operates smoothly.
Step 4: Checking the Tension
It's important to check the bobbin tension as you will get poor results and possibly broken or snagging thread if it's wrong. Fit a bobbin of thread to the bobbin case and thread it under the tension spring. Suspend it by the thread. The tension is correct if it is just sufficient to support the weight of the bobbin and case. Shaking it gently should unwind just a little more thread. Adjust with the screw in the tension spring. If you have any difficulty, make sure there isn't any fluff or pieces of broken thread under the tension spring.
Step 5: Checking the Bobbin Winder
Examine the bobbin winder. This often engages with the hand wheel by means of a wheel with a rubber tyre. If the tyre is worn or cracked or perished, replace it. Spares are generally easy to obtain.
Try winding a bobbin. The thread tension should be sufficient to produce a neat and tight (but not excessively tight) pile. Badly wound bobbins can cause trouble.
(I don't have any pictures of a bobbin winder as it's missing on my machine. I wind my bobbins on a piece of dowel fitted to the chuck of an electric drill.)
Step 6: Checking the Electrics
Before touching any of the electrics, double check that your machine isn't still plugged in.
Smooth operation of the foot pedal is essential otherwise it will be very hard to sew successfully. It may simply need lubricating. On older machines it will contain a rheostat, which is a variable resistance wired in series with the motor. Newer machines will more likely have an electronic speed control similar to a dimmer switch.
You will need to examine the foot pedal to determine how to disassemble it. Do not use sewing machine oil, but rather any light lubricating oil, or grease on sliding parts, and keep oil and grease away from all electrical contacts.
Also, check the motor belt tension. You should be able to adjust it by loosening the screws or nuts on its bracket. If the motor is sparking excessively or doesn't appear to be working well, check out the Electric Motors page on the Restart Project wiki. Replacing the brushes or cleaning the commutator might be necessary. If the motor bearings seem to need lubrication you should use grease specially intended for electric motors, preferably as recommended by the manufacturer.
A replacement bulb is easily fitted on older machines but may be wired-in and not so easily changed on newer ones. Consider replacing a filament bulb with a more modern LED equivalent, which will run much cooler. However, if the bulb needs to shine mainly downwards but the LEDs in a LED bulb appear to face sideways it may be less suitable. Take the old one with you to make sure you get a new one with the same sort of base.
Step 7: Checking the Timing
If you are getting unexplained broken threads, it could be that the timing needs adjustment. This is beyond what can be covered in an Instructable at this level and may be best left to a professional with the appropriate service manual, but it's not too difficult to see whether this is indeed the problem.
You need to be able to see the needle and the hook at the point where the hook catches the top thread. In the photo, I've turned my machine on its side so I can see the underneath, and I've removed the bobbin and and the plate which holds the bobbin carrier in place. I had to hold it to stop it dropping out as I turned the handwheel.
With the needle threaded, turn the handwheel until the hook passes the needle, whilst holding the free end of the thread taught, but without pulling on it. The photo shows the thread having been securely caught after the handwheel has been turned a little further.
The tip of the hook should pass the needle just after it has reached its lowest point. Typically, the needle should have risen 3/16 of an inch (1/10 of an inch, or 2.5mm). At this point, the rising needle causes the thread to go slack and form a loop which is caught by the hook.
Turning the handwheel still further, you should see the thread drawn around the bobbin (if you have it in place) so as to make a stitch.
If having come this far you've got the bug, and if the alternative is to scrap the machine, by all means search online for your make and model of machine with the key words "timing adjustment" appended, and you should at least be able to see what is involved in adjusting the timing. You need to ensure both that the lowest point of the needle brings the eye to the right level beneath the hook, and also that the hook passes the needle after it has risen by the prescribed amount. These settings and how to adjust them should be given in the machine's service manual, if you can get hold of it.
Step 8: And Finally ...
I hope you have enjoyed getting to know your machine better and overcome the fear of looking into quite an intricate and a very ingenious mechanism. If you have a good quality machine, hopefully it will now be purring away contentedly like a cat that's had the cream.
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    1 Questions
    Hi, we have a Reeds sewing machine. It will no longer go through several layers of fabric, breaks thread. We think something may have been bent - sewing pins or a needle. We have cleaned and oiled it and it still won't work correctly....Any suggestions? Or a repair place in MD that services these fine machines?
    I think I give just a little more detail in the version on the Restart Wiki at https://therestartproject.org/wiki/Sewing_machines
    If you still can't fix it and it's an older machine with metal rather than plastic gears then it would probably be well worth searching online for a sewing machine repair specialist local to yourself to look at it for you. More modern machines wear out quite quickly and aren't easily repaired.
    54 Comments
    Hi, thanks for the great instruction! Very happy to stumble upon it, since I just bought the exact same machine as shown above (except mine is called Combi and more roundish, but the rest the same). Do you have any idea what the brand is? Because I couldn't find anything on google.. and that might help with finding an instruction manual on it.
    I'm currently servicing it and with your instructions do the rest as well. Things are going better (it was sewing very slowly on high speed) and after cleaning the lower bits it's running already much faster and smoother. And on top of the motor casing there was a plastic screw with a spring in it. Do you have an idea if tightening this might have amped up the motor or something?
    I'm sorry, I've only just seen your question. No, I'm afraid I don't know what brand it is and I've never found anything online about my specific machine either. Mine was rebranded by a sewing machine shop in the small town where I live.
    Is there a second plastic screw with a spring directly opposite it on the other side of the motor, both of them at the same end of the motor as the wires? These hold the carbon brushes in place which carry the electric current to the rotor. They're not adjustments and should simply be tightened sufficiently not to work loose. The brushes eventually wear down and can be replaced, if you can find the exact same sort. Take a look at he Electric Motors page on the Restart Wiki.
    Thank You. Great pictures and explaining. Helped me tons!
    Glad you found it useful - happy sewing, and thanks for stopping by!
    This blog is very good, I appreciate it, thanks to your writing, so I can spirit in writing in blog for better like you. I am from Indonesia greeting friendship
    Glad you liked it, and thanks for dropping by to say so!
    my Janome has been in its case for the last 10 years. I knew it needed service but I could not remember how. Your tutorial is fabulous and a service is in my near future. Thanks again.
    Glad you liked it, and thanks for stopping by to say so. Have fun!
    Kind regards - Philip
    I have a problem with my wife's sewing machine. Can you help me with a link to a good forum?
    On Yahoo (at least for now . . . )
    We Fix it is huge, a query will often lead to the answer you need. Can be off topic a lot but good people. Some of the other sites are very much "On-topic" moderated by a retired mechanic.
    Often the group files have A LOT of information that is well worth looking over before posting a question that's been asked 1,000 times before. Also links to some great "How to's"
    https://groups.yahoo.com/neo/groups/wefixit/conver...
    https://groups.yahoo.com/neo/groups/vintagejapanse...
    https://groups.yahoo.com/neo/groups/VintageSewingM...
    https://groups.yahoo.com/neo/groups/vintagesingers...
    https://groups.yahoo.com/neo/groups/singerslantsew...
    https://groups.yahoo.com/neo/groups/singermachines...
    https://groups.yahoo.com/neo/groups/sewingmachiner...
    https://groups.yahoo.com/neo/groups/VintageKenmore...
    Ron (with too many machines I'm trying to pare down).
    Thanks, but i just bought a new one this may. I still have the old one but i was considering to sell it for parts.
    The posting will live for a long time, perhaps it will help someone else out.
    I'm afraid I can't recommend any particular forums, especially not knowing what the problem is or the age or make of the machine. I suggest you hang out in a few and see which ones seem to scratch where you itch.
    I think the more appropriate thing to have said about timing would be at least how to check and see if it's off, and if so, refer to service person or more in depth instruction. Checking it is simplicity itself as it's an industry standard applying to just about every machine ever made. When turning the machine by hand, when the needle reaches the bottom of its downward travel look for the hook to be engaging it when it has come back up 3/32 of an inch. This is the magic place where the hook grabs the thread from the needle and throws it over the bobbin case. If you can't verify the timing is correct, there's very little point in servicing or otherwise tinkering with a machine. Most newer machines have a breakaway arm on the mechanism that in the event of a jam, separates the upper from the lower ends of the machine to prevent damage. I worked as an industrial sewing machine mechanic almost 25 years ago and that's about all I remember. Great article, I just didn't feel it went far enough with explanation of the timing.
    The space between Tip of Rotary Hook and Needle is also important as the Hook will slide in and out when screws are loosened.
    Thank you for your helpful comments. I wasn't keen to get into timing as I don't have personal experience of adjusting it, but as you say, explaining in simple terms how to check it shouldn't be hard. I think I tried taking illustrative photos of the hook catching the thread but with the bobbin case etc fully assembled it was pretty hard. I'll maybe have another go.
    Would the fluff, as you call it, affect the grabbing capability of the feeders? I was thinking that my machine might have been ruined by using it for thick materials, but maybe I need to deep clean it?
    You certainly need to clean out all the fluff, and then fit a new needle as the old one might have been dulled or bent by your thick material. Also check whether there's an adjustment for the height of the feed dogs - you will probably need a different setting for lighter material. Check also that the foot is pressing down on the work when it's lowered. I have a slightly more detailed version of this Instructable at https://therestartproject.org/wiki/Sewing_machines which you might like to consult.
    I double checked the manual and I only found an area where it read how to clean under the plate for the feeders, but nothing about adjusting them. My hands are not very dexterous due to the onset of arthritis, but I found a coin as suggested and that worked better than using the small screwdriver. I am embarrassed to say that the feeders were almost plugged up on the left side! I am happy to say that I now have a Brother sewing machine that runs well! Thank you for the site. I saved it.
    Thank you for reporting back - I'm thrilled that you managed to sort it out!
