loading
Step 2: Step 2: Configuring the Microsoft Virtual WiFi Miniport Adapter.
This step will guide you through configuring your newly set-up Microsoft Virtual WiFi Miniport Adapter.
This step will walk you through the process of creating a wireless hotspot using a pre-existing wired (ethernet)  internet connection.
To begin with, if it has not already been done, plug in an ethernet cable into your PC's Ethernet port. Then Navigate to "Network Connections" (From the Network and Sharing Center click on the "Change Adapter Settings" link in the top left hand corner. Enable the virtual adapter, if it is not already enabled, by right clicking on the adapter and pressing enable.  Once you have internet connectivity via the Ethernet cable and the virtual adapter is enabled, right click on the "Local Area Connection" button and click "Properties". Once the dialogue box pops up, click on the "Sharing" tab. From here click the check box labeled "Allow other Network Users to connect through this Computer's Internet Connection". Click on the Drop down box "Home networking connection" labeled "Select a private network connection" and select the Microsoft Virtual WiFi Miniport Adapter which should be labeled "Wireless Network Connection 2". Click "OK" and the "Local Area Connection" button should now say "Shared".
<p>Once I readded the service &quot;Internet Connection Sharing&quot; and then enabled it from the &quot;control panel/administrative tools\services&quot; ALL my wifi router applications started working again without issue, I love this forum and the page I found, thanks to you all :-) WoooooooHoooooooo!!!!!!!</p>
<p>I had the same problem, my cat walked over my keyboard multiple times while i slept, damn that cat, but, I found after days of messing around that my &quot;Internet Connection Sharing&quot; in services no longer existed and I had the same errors as everyone else here so I found this web page and merged the registry settings for my missing stuff, hope this helps everyone else here and thank you all for your pointers and advise, it really directed me to the fault I had. Now I have to remember exactly what else I changed trying to find out what was wrong and put all that stuff back to where it was before I started messing :-D Oh before I forget here is the link to many registry and service settings that you may or may not need, be careful with these they can be lethal ;-) https://www.sevenforums.com/tutorials/236709-services-restore-default-services-windows-7-a.html</p>
<p>Sharing my experience to say,if someone need windows product keys,you can go to <a href="http://www.vanskeys.com" rel="nofollow"> www.vanskeys.com</a> to got.I'm here to buy a key, a hundred percent genuine.</p>
<p>You can watch video : 100% success</p><p><iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/HhBn0TOkd8c" width="500"></iframe></p>
<p>You can activate windows 7 easily if you are willing to spend a little money buying a cheap product key, this site: <a href="http://www.aakeys.com" rel="nofollow"> www.aakeys.com </a> offers very cheap product keys, you can go to have a look.</p>
<p>Hey all,I have installed the a wifi hotspot on my pc windows 7 but when I start it ,the error message come said&quot;Can not create the Microsoft virtual wifi miniport adapter&quot;,Help me </p>
<p>Thank you for your instruction. My friend said it worked. But I downloaded <a href="http://www.drivethelife.com/free-wifi-hotspot-creator.html" rel="nofollow">OSToto Hotspot</a> for my Windows 10, which could allow me to blacklist and cancel it anywhere any time. I really enjoy the security. </p>
<p>I didn't hear about OSToto Hotspot, I used <a href="http://www.connectify.me/" rel="nofollow">Connectify</a> before. Thanks a lot for your link. Seems like OSToto is much better for me. Good luck :-)</p>
<p>bro better instruct with images like here</p><p>http://www.techtweetz.com/how-to-create-wifi-hotspot-on-windows-7-8-1-10/</p>
<p>why it is working only 2 to 3 mintues.. </p>
<p>it's working only for 2 or 3 minutes . please help me for this problem.</p>
<p>worked for me thx</p>
<div>I installed Connectify for using my ethernet to my android <br>phone, but it is not working. I shared my ethernet to name of <br>connectify. Some I-phone is connected but android phone is not been <br>connected. It shows some authentication problem. please help me as soon <br>as possible.</div>
<p>it works man thank you. nice posting.</p>
It worked well for the first time. But next time it dont share internet anymore .....what to do? Pls help and thanks in advance<br>
<p>its working fine but how to disable it </p>
<p>to turn it off u can do it by<br>netsh wlan stop hostednetwork<br>and to check its running status you can do<br>netsh wlan show hostednetwork</p>
<p>It writes &quot;The hosted network couldn't be started.<br>The group or resource is not in the correct state to perform the requested operation.&quot; when I type into PoweShell &quot;netsh wlan start hostednetwrok&quot; &amp; don't shows &quot;Wireless Network Connection 2&quot; (((( What can I do?</p>
<p>I have a problem when I want to turn on the acces point, after I tipe netsh wlan start hostednetwork in cmd it says : The hosted network couldn't be started. The group or resource is not in the correct state to perform the requested operation. </p><p>Any idea what to do ? </p><p>Thanks</p>
<p>I have a problem when I want to turn on the acces point, after I tipe netsh wlan start hostednetwork in cmd it says : The hosted network couldn't be started. The group or resource is not in the correct state to perform the requested operation.</p><p>Any idea what to do ? </p><p>Thanks</p>
<p>Works as it should and splendid. Thank you so much. :-)</p>
<p>hey man i did as u told n in the 3rd step i typed netsh wlan start hostednetwork</p><p>but then when i press enter an error comes - the hosted network couldn't be started. A device attached to the system is not functioning. What does this mean? What do I do? Pls rply ASAP</p>
<p>i did like u said but it didnt work &gt;_&lt; help!</p>
<p>First check whether your wi-fi adopter supports hosted network or not. Not all adopters support hosted network . use &quot;netsh wlan show drivers&quot; and check for &quot;hosted network supported: yes&quot; </p>
<p>im successfully creat the hotspot network.....but im unable to share it with my network.....its says error1058 the service cannot be started either because it is disable or because it has no enable device associated with it......then i search for the service n enable the service but still not wrking....same msg error.........is coming</p>
<p>http://support.microsoft.com/kb/241584 hears a fix </p>
<p>I did the method for more than 100 times....NO USE...:-((</p><p>Guys who made it possible may explain what devices they used...or what is the usb wifi adapter they used to connect the wifi enabled devices...for help..:-))</p>
<p>Hi elango1963,</p><p>I had a method that would helped your problem...as maybe, if you want to share your internet connection you should to be a HOTSPOT server :) to start follow these short steps: 1. Go to start search program type CMD, when you find it just right click on it and RUN AS ADMINISTRATOR...</p><p> 2. In the command prompt type this: netsh wlan set hostednetwork mode=allow ssid=&quot;YOUR DESIRED NAME &quot; key=&quot;YOUR DESIRED PASSWORD&quot;</p><p>and press ENTER.</p><p> 3. Next type this to start your hotspot prog. : netsh wlan start hostednetwork, and press ENTER.</p><p> 4. NOW YOUR DONE!!!!! go to CONTROL PANEL-network and internet-NETWORK SHARING CENTER and click the CHANGE ADAPTER SETTINGS and look for your ACTIVE INTERNET example: BROADBAND/ wifi then right click on it then CLICK PROPERTIES select the tab SHARING in the Internet Connection Sharing (ICS) select allow network user...... and on the HOME NETWORKING CONNECTION select your CREATED &quot;hotspot&quot; and click OK.</p><p>that's it!!!! your friend's laptop can connect in your pc for you have created a HOTSPOT :) </p><p>I hope you will admire...HAPPY VALENTINES TO Feb. 14, 2015 &lt;3</p>
<p>Waaaoo.. I love you man. It worked. :)</p>
<p>thanks a lot :)</p>
<p>Totally Worked for me! </p><p>This awesome tutorial fixed the *last unresolved issue* with my Bootcamp installation of Win7.</p><p>I finally can use my Macbook as a Hotspot whether I am running OSX or Win7, pshhhhhh took me almost 6 month to find this tip!</p>
<p>My connections continues to say obtaining IP address... and wont connect... any advise?</p>
<p>Don't have LAN so did it via my wireless connection and it worked perfectly!</p>
<p>i followed ur three steps to connect to wifi hotspot but it is appearing as a device is not functioning</p>
<p>hello, i did the whole proccess but now i cant connect any devices to my hotspot. it stops at requiering IP adress and it just wont connect... help please.</p>
<p>very nice..thanks a lot</p>
<p>i have problem with microsoft virtual wifi miniport adapter it shows yellow mark in device manager can you plz help me to fix the driver.</p>
<p>I made my wifi hotspot but by mistake i clicked on the disable key..!!! I wasn't able to access..! I tried to make a new wifi hotspot but it's not starting up.! What shall i do now..??</p>
<p>I am able to setup the adapter, but not getting any sharing option in the adapter properties. Please help.</p>
<p>other way, can you can me how to connect my Net pack from Nokia 5130 XPressMusic to Micromax Canvas Nitro A310 directly over bluetooth</p><p>Thanks for any help *_*</p>
About This Instructable
926,085views
73favorites
License:
More by ghostmonkeys:How to set up a wireless hotspot - From WiFi (Windows 7) How to Set Up a Wireless Hotspot - From Ethernet (Windows 7)
Add instructable to:
