Introduction: +1-844-355-5111 How to Setup, Refill, Replace or Change Ink Cartridges on the HP All-In-One Printer?
Tips to Setup, Install Ink Cartridges On the HP Printers
Installing HP cartridges to HP printer is fairly simple if all the instruction of setting up is being followed, however, a minor problem in setting up cartridges can ruin your printing. To ensure the quality printing it is important users to correctly assemble the cartridges. This simple instruction improves your printing experience, instead of calling HP printer support phone number, do it your own.
Primarily, ensure that you bring correct printer cartridges for your printer, when you are going to buy a cartridges, don’t forget to bring printer model number. Correct printer number is printed above the printer cartridges box. Visit, HP support for more details. In general, cartridges are manufactured for one series of printers. Support you have a HP jet 710, you can look for the HP Jet 700 series cartridges.
“Tips to Remove old HP ink cartridges”
Remove old HP ink cartridges to recycle them, and remove blue film from the nozzle of the HP printer cartridges, turn the cartridges so that HP logo facing you. The grey part of the cartridges faces up and a nozzle goes downwards. Depending on the printer model cartridges have some black dots on the Top. Install the each cartridge in every color row. Push them firmly, but don’t push it too hard.
Keep in Mind
See the readout of the printer, if your cartridges is used before, select used or if it used first time, select new. Check if paper is loaded in paper tree, open your HP print manager and select setting and maintenance and select align print cartridges.
Take out the newly printed paper from the paper tray; you will see two dot lines parallel in red and black. Examine the alignment of the lines, click the numbers and letters for the best alignment, a dialogue box will appear to your screen, click continue, a new page will be print, now check whether these alignments are correctly printed on the paper, if you found irregularity over alignments, repeat this step 3 or 4 times to continue.
