How to Setup Your Skateboard
Published
Introduction: How to Setup Your Skateboard
Here i will show you how to quickly setup your skateboard in just a couple easy steps
Step 1: These Are the Things You Need
#1 deck
#2 griptape (mine is pre gripped)
#3 trucks
#4 hardware
#5 bearings
#6 spacers (optional)
#7 wheels
And a skate tool ( you can also use a wrench and a philips head screw driver or allen key
Step 2: First Tighten the Trucks
Put screws through the drilled holes from the top and tighten the nut on the bottom repeat with all the rest of the holes and remember always put the side with bushings toward the inside
Step 3:
Push the bearings in the wheels with a spacer in between bearings and tighten the nut but not all the way leave a small amount of wiggle room in between the bearing and nut
Step 4:
Then put on skate shoes and skate safe and have fun
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    3 Comments
