How to Setup an IC2 Display to Arduino
Published
Introduction: How to Setup an IC2 Display to Arduino
Have you ever wanted to hook up an LCD display to Arduino but found out its really difficult. Well this is how I hooked it up so you can follow along and easily connect a display to arduino to print out information easily
Step 1: Wiring the Connections
For wiring the connections you will need to wire arduino to your lcd and this is how
SDA to A4
SCL to A5
Gnd to Gnd
Vcc to 5v
Step 2: Finding Your IC2 Bus Address
This address is necessary in order to allow your arduino to effectively talk to you display and this address can be found by simply running this code:https://github.com/RobTillaart/Arduino/tree/master...
and then going to serial display and chang the baud to 11520. Then type in s and enter. Now scroll up to get your address.
Step 3: Programming Your IC2 Display
Now in order to do this you will first need to go to sketch, include library, manage library and download liquid crystal IC2. After this you can use my program that took 10 seconds to throw together and edit the bus address to yours and edit the text to what you want it to say.
my code: https://www.dropbox.com/s/8io4d8z394aono9/ic2%20si...
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    4 Comments
    the scan gives no results
    it says it din't found annything to 350 milliseconds
    i found the solution: i was working with a Arduino Nano. You can only do this with a uno
    hello, in your video it says to hook SDA to 4, but in the text above it says SDA to 5. is the video correct? thanks
    Sorry my bad I wrote it down wrong its SDA to 4!
