How to Setup and Bypass a Protected File Using CMD
1,424
15
Posted
Introduction: How to Setup and Bypass a Protected File Using CMD
In this instructable, you will be learning how to setup and bypass a password protected file which using the Command Line or "Command Prompt".
Step 1: Creating a Password Protected File Using CMD!
1. Go ahead and open a fresh document in notepad or notepad++ (downloadable).
2. Copy the following text, changing all words in [BRACKETS] to your preffered choice/word.
cls
@ECHO OFF
title Security
if EXIST "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" goto UNLOCK
if NOT EXIST MyFolder goto MDMyFolder
:CONFIRM
echo Are you sure you would like to lock this folder? (Y/N)
set/p "cho=>"
if %cho%==Y goto LOCK
if %cho%==y goto LOCK
if %cho%==N goto END
if %cho%==n goto END
echo Invalid Choice.
goto CONFIRM
:LOCK
ren MyFolder "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
attrib +h +s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
echo Folder Locked.
goto End
:UNLOCK
echo Enter password to Unlock your Secure Folder
set/p "pass=>"
if NOT %pass%== [PASSWORD GOES HERE] goto FAIL
attrib -h -s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
ren "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" MyFolder
echo Folder Successfully Unlocked.
goto End
:FAIL
echo Invalid Password.
goto End
:MDMyFolder
md MyFolder
echo MyFolder created successfully
goto End
:END
3. Please note, if there are any bugs or the lock seems to be not working please comment below.
You can alternatively change the name of the "secret" folder by changing all accounts of MyFolder
to your preferred "secret" folder name.
Step 2: How to Bypass a Password Protected File Which Uses CMD.
Not many people know how to bypass this type of password protected file, unless they are tech savvy. Remember, bypassing is still easy and POSSIBLE! This step is for Educational Purposes ONLY! I am NOT RESPONSIBLE if you find yourself dealing with the police.
1. Select and right-click the batch file (command prompt).
2. Select Edit.
3. You will now see a most-likely gibberish language, which enables us to run this password protect.
4. Scroll down to the :UNLOCK section of the text file.
5. You will then see a line of text, or "command/code" which will say: if NOT %pass%== [PASSWORD DISPLAYED HERE] goto fail
6. Now go back and run the batch file. In the previous step, you obtained the password to enter the "secret" folder. Use this password to enter through the password system.
7. Walaahhh! You have now gained access to the "secret" file/folder.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    Thanks for sharing!
